On October 5, 2014 1:39:31 PM CEST, Pavel Maslov < [email protected]> wrote:
Yeah, but what it does is it copies the tarball to INSTALL_LOCATION and starts build from there (which I don't need). What I meant if it is possible to build from current directory, so that after the build you can manually (or using a script, make install, etc) put everything to INSTALL_LOCATION, and all the libraries and IOCs linked to them will not be broken.
Pavel,
I don't know what kind of build system you are using, but setting INSTALL_LOCATION inside a make based build of a standard EPICS application does exactly what you describe. It builds locally and installs into the selected location (instead of TOP).
Are you using the make rules from EPICS Base?
Cheers,
~Ralph
- Re: [EPICS] Support for Staged Installs ? Michael Davidsaver
- [EPICS] Support for Staged Installs ? Pavel Maslov
- Re: [EPICS] Support for Staged Installs ? Ralph Lange
- Re: [EPICS] Support for Staged Installs ? Pavel Maslov
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
