1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: IOC server on windows or access a PV
To: [email protected]
Cc: [email protected]
Date: Fri, 03 Oct 2014 09:35:27 +0200
Dear Mark,
Thanks for confirming my idea of the "simplest" solution :-)
I am concerned with the timestamp of the PV. Is it given by the IOC server or the machine where I do the "caput" operation?
Best regards,
Zunbeltz
og., 2014.eko urrren 02a 22:13(e)an, Mark Rivers igorleak idatzi zuen:
Hi Zunbeltz,
For what you propose, using a client to do a Channel Access “put” operation to an existing IOC on a Linux server is probably the simplest solution.
> Is it possible to create an  PV that is not associated with any hardware in a IOC server? Is it enough to add a record in the ioc.db file?
Yes, you can just load the new records you need to the IOC database.  There is no need for them to be associated with hardware.
You can write your Windows Channel Access client software in a wide variety of languages: shell script, Python, Perl, IDL, C/C++, etc.
It is also not difficult to create an IOC on the Windows machine, but then you are forced to write your software in C or C++.
From: [email protected] [mailto:[email protected]] On Behalf Of zunbeltz
Sent: Thursday, October 02, 2014 2:49 PM
Subject: IOC server on windows or access a PV
Dear all,
We need to pass some values, calculated from photographs, to the EPICS network from a windows machine.
Is it easy to install an IOC server in a windows machine?
If not, our idea is to create the PVs in an already running IOC server (on linux), and use caput tool (from the EPICS Extensions http://aps.anl.gov/epics/distributions/win32/index.php) to update the values.
Thanks in advance for your help.
Zunbeltz
Dr. Zunbeltz Izaola
Accelerator Physics Group
ESS-Bilbao
Dr. Zunbeltz Izaola
ESS-Bilbao
IOC server on windows or access a PV zunbeltz
RE: IOC server on windows or access a PV Mark Rivers
Prev: Re: IOC server on windows or access a PV zunbeltz
Next: Re: IOC server on windows or access a PV Xiaoqiang Wang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: IOC server on windows or access a PV Mark Rivers
Next: Re: IOC server on windows or access a PV Mark Engbretson
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
