Dear Mark,
Thanks for the information; but I think will first try to use an
existing IOC server on linux.
By the way, what is NSSM stands for? I was unable to find it.
Zunbeltz
og., 2014.eko urrren 02a 22:37(e)an,
Mark Engbretson igorleak idatzi zuen:
A windows soft IOC is built as part of the utility
applications when you build and recent version of EPICS with
windows compilers. If you download software like NSSM, you can
start the soft IOC when the computer boots. You can then write
simple databases of most just ai records to hold values.
Not sure what mods you might need to make if you want values
persistence across reboots.
Sent from my iPad 4
Dear all,
We need to pass some values, calculated from photographs, to
the EPICS network from a windows machine.
Is it easy to install an IOC server in a windows machine?
If not, our idea is to create the PVs in an already running
IOC server (on linux), and use caput tool (from the
EPICS Extensions http://aps.anl.gov/epics/distributions/win32/index.php)
to update the values.
Is it possible to create an PV that is not associated with any
hardware in a IOC server? Is it enough to add a record in
the ioc.db file?
Thanks in advance for your help.
Zunbeltz
Dr. Zunbeltz Izaola
Accelerator Physics Group
ESS-Bilbao
Dr. Zunbeltz Izaola
ESS-Bilbao
- IOC server on windows or access a PV zunbeltz
- Re: IOC server on windows or access a PV Mark Engbretson
RE: IOC server on windows or access a PV Bertrand Alain Gregor
Re: IOC server on windows or access a PV zunbeltz
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
