hi, all: I am trying to use s7-nodave EPICS driver, the db file is like following: record(ai,"$(id):ai")
{ field(DESC,"") # field(SCAN, "I/O Intr") field(DTYP,"s7nodave") field(INP,"@t1plc MD4 int32") } when running st.cmd, it shows no errors: #!../../bin/linux-x86/t1 < envPaths
epicsEnvSet("ARCH","linux-x86") epicsEnvSet("IOC","ioct1") epicsEnvSet("TOP","/home/geyang/t1App") epicsEnvSet("EPICS_BASE","/usr/local/epics/r3.14.12.3/base") epicsEnvSet("ASYN","/usr/local/epics/r3.14.12.3/modules/asyn4-13") epicsEnvSet("S7NODAVE","/home/geyang/s7nodave-1.0.3") cd /home/geyang/t1App dbLoadDatabase "dbd/t1.dbd" t1_registerRecordDeviceDriver pdbbase s7nodaveConfigureIsoTcpPort("t1plc", "192.168.1.7", 0) s7nodaveConfigurePollGroup("t1plc", "default", 1, 0) dbLoadRecords "db/t1.db", "id=t1" cd /home/geyang/t1App/iocBoot/ioct1 iocInit Starting iocInit ############################################################################ ## EPICS R3.14.12.3 $Date: Mon 2012-12-17 14:11:47 -0600$ ## EPICS Base built Sep 25 2014 ############################################################################ The CA server's beacon address list was empty after initialization? iocRun: All initialization complete epics> dbl t1:ai epics> dbpr t1:ai ASG: DESC: DISA: 0 DISP: 0 DISV: 1 NAME: t1:ai RVAL: 0 SEVR: INVALID STAT: UDF SVAL: 0 TPRO: 0 VAL: 0 epics> but I can't get the correct val from S7 plc. If I use the test program "testiso_tcp" coming with libnodave, I can exchange data with my S7-300 PLC. Can anyone give me some suggestions? Thanks a lot for your help.
Best wishes
Geyang 2014-09-25
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
