1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Record timestamp does not update (Debian Linux only)
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 23 Sep 2014 18:11:41 +0900
Dear all,
I just found this problem on two different Debian machines (testing,
unstable), x86_64. On Scientific Linux (6.5), also x86_64, the problem
does not show up. With softIoc from base 3.14.12.4 for this DB:
record(ao, "VOLT:set")
   field(VAL,  "5")
   field(PINI, "1")
record(calcout, "VOLT:calc")
   field(OOPT, "When Non-zero")
   field(DOPT, "Use OCAL")
   field(OCAL, "A")
   field(CALC, "1")
   field(OUT,  "VOLT:set")
   field(INPA, "VOLT:req CP")
record(ao, "VOLT:req")
   field(VAL,  "5")
   field(PINI, "1")
I see that the time stamp of VOLT:set does not change when writing to
VOLT:req, but the value changes as expected:
TIME: 2014-09-23 18:04:16.464355407     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 0              VAL: 5
TSEL:CONSTANT       UDF: 0              VAL: 2
TSEL:CONSTANT       UDF: 0              VAL: 0
after IOC initialization, caput VOLT:req 2, and caput VOLT:req 0
respectively.
The time stamps of VOLT:calc and VOLT:req are updated as expected.
Can anybody reproduce this behavior?
Best regards,
Michael Ritzert
Dr. Michael Ritzert                     Tel: +49 621 181 2883
Schaltungstechnik und Simulation        Fax: +49 621 181 2734
Technische Informatik, Uni Heidelberg   [email protected]
68131 Mannheim, Germany                 http://sus.ziti.uni-heidelberg.de
Re: Record timestamp does not update (Debian Linux only) Ralph Lange
Prev: Bug in autosave 5.4 Ralph Lange
Next: Re: snmp error Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Bug in autosave 5.4 Mooney, Tim M.
Next: Re: Record timestamp does not update (Debian Linux only) Ralph Lange
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
