Which EPICS SNMP driver are you using? I've written one some people
use for Wiener ISEGs, but there are others.
Here's ours:
<https://groups.nscl.msu.edu/controls/#SNMP>
That's not an error response I can find grepping my code either.
On 9/19/2014 11:13 AM, Pierrick Hanlet
wrote:
I've an error with snmp that I've never seen before and cannot
find in tech-talk repositories.
I have some devices which I talk to via snmp. I have no errors in
compilation, nor starting
my (soft) IOC, however they occur for each record which attempts
to make the snmp call.
When I use snmp v2c, the error message is:
Record [PVname] parsing response [No Such Instance currently
exists at th] error!
When I use snmp v1, the error message is:
Record [PVname] parsing response [ NULL] error!
I'm on an SL6.4 machine and am using V 3.4.12.3
When I do a recursive grep on base, I cannot even find snippets of
this error message.
An additional mystery is that the code hasn't changed and used to
work when I was
running with SL5.7.
Any ideas?
Pierrick
"Whether you think you can or think you can't, either way, you
are correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
John A. Priller | Phone : (517) 908-7375
MSU Cyclotron Laboratory | Fax : (517) 908-7126
640 S. Shaw Lane room 1300D | Email : [email protected]
East Lansing, MI 48824 | Web : http://people.nscl.msu.edu/~priller/
snmp error Pierrick Hanlet
Building EPICS base in Windows mreza
<2014>
Re: snmp error Dirk Zimoch
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
