Thanks Lewis,
I replaced the tilde chararcter. Nothing changed.
Let me ask this way: Is RULES_JAVA supported? Is there any better solution?
What is "standard" build mechanism for EPICS Java application?
Nerses
----- Original Message -----
To: "Nerses Gevorgyan" <[email protected]>, [email protected]
Sent: Tuesday, September 16, 2014 10:50:44 AM
Subject: Re: Is RULES_JAVA broken?
On 9/15/14, 11:00 PM, Nerses Gevorgyan wrote:
> The Makefile is quite simple.
> vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
> TOP=../..
> JAVA_DIR = ~rafopar/Apps/Java/jdk1.7.0_67
Hi, Nerses.
I've never used RULES_JAVA, so I'm not commenting on any of your
reported problems, except I will say that your use of a tilde character
('~') in your JAVA_DIR path might be a problem. That is normally a
special syntax recognized by certain shells that will be expanded to a
user's home directory. That might not work as you're expecting in GNU
Make. I suggest replacing that with an absolute path.
Lewis
- Re: Is RULES_JAVA broken? J. Lewis Muir
- Re: Is RULES_JAVA broken? Andrew Johnson
Re: Question about asyn and offline device Sonya Hoobler
<2014>
<2014>
