I'm trying to build a simple java application consisting of one java file.
After getting into troubles, I've tried to debug and found some "problems" in the $EPICS_BASE/configure/RULES_JAVA
I found at least 2 places I need to make changes in the RULES_JAVA.
In short the question is: is RULES_JAVA is tested and I'm doing something wrong or the RULES_JAVA should be fixed?
Below, are more details about the problem.
The EPICS_BASE is R3.14.12.3
So, the structure of files and directories similar to the application created by makeBaseApp.pl
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
nerses@clonioc1 apps>find MakeLogEntryApp -ls
4088280 4 drwxrwxr-x 3 nerses clas-4 4096 Sep 15 22:48 MakeLogEntryApp
4088281 4 -rw-rw-r-- 1 nerses clas-4 304 Sep 11 15:23 MakeLogEntryApp/Makefile
4088282 4 drwxrwxr-x 3 nerses clas-4 4096 Sep 15 22:59 MakeLogEntryApp/src
4088289 4 -rw-rw-r-- 1 nerses clas-4 1898 Sep 15 18:13 MakeLogEntryApp/src/Makefile
4088296 4 drwxrwxr-x 3 nerses clas-4 4096 Sep 15 22:48 MakeLogEntryApp/src/org
4088297 4 drwxrwxr-x 3 nerses clas-4 4096 Sep 11 16:49 MakeLogEntryApp/src/org/jlab
4088298 4 drwxrwxr-x 2 nerses clas-4 4096 Sep 15 22:54 MakeLogEntryApp/src/org/jlab/AutoLogEntry
4088299 12 -rw-rw-r-- 1 nerses clas-4 9964 Sep 11 16:49 MakeLogEntryApp/src/org/jlab/AutoLogEntry/MakeLogEntry.java
The Makefile is quite simple.
TOP=../..
JAVA_DIR = ~rafopar/Apps/Java/jdk1.7.0_67
include $(TOP)/configure/CONFIG
JAVA += org/jlab/AutoLogEntry/MakeLogEntry.java
JAR += MakeLogEntry.jar
JAR_INPUT = $(INSTALL_CLASSES)
#JAR_INPUT = $(INSTALL_JAVA)/org/jlab/AutoLogEntry/MakeLogEntry.*
USR_JAVACFLAGS += -cp .:/u/site/ace/certified/apps/eloglib/java/jlog2.jar:/home/rafopar/JAR_Files/mysql-connector-java-5.1.32-bin.jar
include $(TOP)/configure/RULES
# ADD RULES AFTER THIS LINE
mytest:
@echo JAVA_INC = $(JAVA_INC)
@echo JAVA_BIN = $(JAVA_BIN)
@echo JAVA_INCLUDES = $(JAVA_INCLUDES)
@echo JAVACCMD = $(JAVACCMD)
@echo JAVAHCMD = $(JAVAHCMD)
@echo JARCMD = $(JARCMD)
#vpath %.java ..
@echo CLASSPATH = $(CLASSPATH)
# Java directory
@echo JAVA = $(JAVA)
@echo JAVA_DIRECTORY_TARGETS = $(JAVA_DIRECTORY_TARGETS)
# Java native method C header files
@echo JAVAHFLAGS = $(JAVAHFLAGS)
@echo JAVAINC_CLASSFILES = $(JAVAINC_CLASSFILES)
@echo JAVAINC_CLASSNAMES = $(JAVAINC_CLASSNAMES)
@echo COMMON_JAVAINC = $(COMMON_JAVAINC)
# Java class files
@echo JAVACFLAGS = $(JAVACFLAGS)
@echo CLASSES = $(CLASSES)
@echo INSTALL_CLASSES = $(INSTALL_CLASSES)
@echo TESTCLASSES = $(TESTCLASSES)
@echo DEPTESTJAVA = $(DEPTESTJAVA)
# Java jar file
@echo INSTALL_JAR = $(INSTALL_JAR)
@echo JARDEPFILES = $(JARDEPFILES)
@echo JARINPUT = $(JARINPUT)
@echo JARPACKAGES = $(JARPACKAGES)
@echo PACKAGEDIRS = $(PACKAGEDIRS)
# Java doc definitions
@echo JAVADOC = $(JAVADOC)
@echo JAVADOCFLAGS = $(JAVADOCFLAGS)
@echo JAVADOCCMD = $(JAVADOCCMD)
@echo INSTALL_JAVADOC = $(JAVADOCCMD)
The compilation of java file is running smoothly.
The javalib directory is created in the TOP directory and results are placed there.
nerses@clonioc1 apps>find javalib/ -ls
1207269 4 drwxrwxr-x 3 nerses clas-4 4096 Sep 15 23:00 javalib/
1207270 4 drwxrwxr-x 3 nerses clas-4 4096 Sep 15 23:00 javalib/org
1207271 4 drwxrwxr-x 3 nerses clas-4 4096 Sep 15 23:00 javalib/org/jlab
1207272 4 drwxrwxr-x 2 nerses clas-4 4096 Sep 15 23:00 javalib/org/jlab/AutoLogEntry
1207273 4 -rw-rw-r-- 1 nerses clas-4 1205 Sep 15 23:00 javalib/org/jlab/AutoLogEntry/MakeLogEntry$Action.class
1207274 4 -rw-rw-r-- 1 nerses clas-4 962 Sep 15 23:00 javalib/org/jlab/AutoLogEntry/MakeLogEntry$ScrollablePanel.class
1207275 4 -rw-rw-r-- 1 nerses clas-4 231 Sep 15 23:00 javalib/org/jlab/AutoLogEntry/MakeLogEntry$1.class
1207276 8 -rw-rw-r-- 1 nerses clas-4 8000 Sep 15 23:00 javalib/org/jlab/AutoLogEntry/MakeLogEntry.class
The next step is creation of jar file which is failing.
Here is the output of make.
nerses@clonioc1 src>make
perl /usr/local/clas12/release/0.1/R3.14.12.3/base/bin/linux-x86/makeMakefile.pl O.linux-x86 ../../..
perl /usr/local/clas12/release/0.1/R3.14.12.3/base/bin/linux-x86/makeMakefile.pl O.vxWorks-ppc604_long ../../..
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[1]: Entering directory `/misc/home/nerses/github_test/epics/apps/MakeLogEntryApp/src/O.linux-x86'
mkdir -p ../../../javalib
Creating java class files
~rafopar/Apps/Java/jdk1.7.0_67/bin/javac -classpath ../../../javalib -sourcepath .:..:../.. -cp .:/u/site/ace/certified/apps/eloglib/java/jlog2.jar:/misc/home/rafopar/JAR_Files/mysql-connector-java-5.1.32-bin.jar -d ../../../javalib ../org/jlab/AutoLogEntry/MakeLogEntry.java
make[1]: *** No rule to make target `../../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class', needed by `../../../javalib/../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class'. Stop.
make[1]: Leaving directory `/misc/home/nerses/github_test/epics/apps/MakeLogEntryApp/src/O.linux-x86'
make: *** [install.linux-x86] Error 2
As You see it looks something in wrong non-existing directory
(../../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class)
instead of
(../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class)
By digging into $EPICS_BASE/configure/RULES_JAVA I found that probably the JAVADEPFILES variable is wrong as seen from mytest target.
nerses@clonioc1 src>make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 mytest
make: Entering directory `/misc/home/nerses/github_test/epics/apps/MakeLogEntryApp/src/O.linux-x86'
INSTALL_CLASSES = ../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class
INSTALL_JAVA = ../../../javalib
JARINPUT = -C ../../../javalib ../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class
JAR_INPUT = ../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class
JARPACKAGES =
JARCMD = /home/rafopar/Apps/Java/jdk1.7.0_67/bin/jar cvf mytest -C ../../../javalib ../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class
JARDEPFILES = ../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class ../../../javalib/../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class
JAVA_INC = /home/rafopar/Apps/Java/jdk1.7.0_67/include
JAVA_BIN = /home/rafopar/Apps/Java/jdk1.7.0_67/bin
JAVA_INCLUDES = -I~rafopar/Apps/Java/jdk1.7.0_67/include -I~rafopar/Apps/Java/jdk1.7.0_67/include/linux -I../O.Common
JAVACCMD = /home/rafopar/Apps/Java/jdk1.7.0_67/bin/javac -classpath ../../../javalib -sourcepath .:..:../.. -cp .:/u/site/ace/certified/apps/eloglib/java/jlog2.jar:/misc/home/rafopar/JAR_Files/mysql-connector-java-5.1.32-bin.jar
JAVAHCMD = /home/rafopar/Apps/Java/jdk1.7.0_67/bin/javah -d ../O.Common -force -classpath ../../../javalib
CLASSPATH = -classpath ../../../javalib
JAVA = org/jlab/AutoLogEntry/MakeLogEntry.java
JAVA_DIRECTORY_TARGETS = ../../../javalib
JAVAHFLAGS =
COMMON_JAVAINC =
JAVACFLAGS = -cp .:/u/site/ace/certified/apps/eloglib/java/jlog2.jar:/misc/home/rafopar/JAR_Files/mysql-connector-java-5.1.32-bin.jar
CLASSES = org/jlab/AutoLogEntry/MakeLogEntry.class
TESTCLASSES =
DEPTESTJAVA =
INSTALL_JAR = ../../../javalib/MakeLogEntry.jar
JARPACKAGES =
PACKAGEDIRS =
JAVADOC =
JAVADOCFLAGS =
JAVADOCCMD =
INSTALL_JAVADOC =
make: Leaving directory `/misc/home/nerses/github_test/epics/apps/MakeLogEntryApp/src/O.linux-x86'
By changing from
JARDEPFILES += $(addprefix $(INSTALL_JAVA)/,$(subst .java,.class,$(JAVA)) $(JAR_INPUT))
to
JARDEPFILES += $(addprefix $(INSTALL_JAVA)/,$(subst .java,.class,$(JAVA))) $(JAR_INPUT)
I got the following:
Creating java jar file ../O.Common/MakeLogEntry.jar
~rafopar/Apps/Java/jdk1.7.0_67/bin/jar cvf ../O.Common/MakeLogEntry.jar -C ../../../javalib ../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class
../../../javalib/../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class : no such file or directory
added manifest
make[1]: *** [../O.Common/MakeLogEntry.jar] Error 1
rm ../O.Common/MakeLogEntry.jar
Which means instead of command:
should be change to produce one of the following:
~rafopar/Apps/Java/jdk1.7.0_67/bin/jar cvf ../O.Common/MakeLogEntry.jar -C ../../../javalib org/jlab/AutoLogEntry/MakeLogEntry.class
~rafopar/Apps/Java/jdk1.7.0_67/bin/jar cvf ../O.Common/MakeLogEntry.jar ../../../javalib/org/jlab/AutoLogEntry/MakeLogEntry.class
This means that JARINPUT is producing the problem:
So, the following line from RULES_JAVA
JARINPUT += $(foreach inp,$(JAR_INPUT),-C $(INSTALL_JAVA) $(subst .java,.class,$(inp)))
should become
JARINPUT += $(foreach inp,$(JAR_INPUT), $(subst .java,.class,$(inp)))
or
JARINPUT += $(foreach inp,$(JAR_INPUT),-C $(INSTALL_JAVA) $(subst $(INSTALL_JAVA),,$(subst .java,.class,$(inp))))
Nerses
- Re: Is RULES_JAVA broken? J. Lewis Muir
Re: EPICS vs. Firewalls J. Lewis Muir
Asyn model 3 driver for Galil products Mark Clift
<2014>
Re: EPICS vs. Firewalls Konrad, Martin
<2014>
