1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Keithley 2400 communication
To: <[email protected]>, <[email protected]>
Date: Thu, 11 Sep 2014 08:19:42 +0000
You need to use some existing Keithley 2400 device support (there is asyn support at  http://www.aps.anl.gov/epics/download/modules/keithley2400-1.1.tar.gz or I can send you the Diamond version based on StreamDevice – I have attached the protocol file as a starter).
You then either use your choice of programming method (typically a sequence record or a SNL program) to chain all the commands together.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
Sent: 11 September 2014 08:20
To: [email protected]
Subject: Keithley 2400 communication
Hello,
        I am trying communication with KEITHLEY 2400 on serial port(RS-232).I sent command "*IDN?" it has performed very well and i got the output.
i want to reset the device and the commands are
*RST
:SOUR:FUNC VOLT
:SOUR:VOLT:MODE FIX
:SOUR:VOLT:RANG 20
:SOUR:VOLT:LEV 10
:OUTP ON
:READ?
now,How to write program in VDCT for performing all commands sequentially.Actually i have no idea about this.please help me....
Q.2: How to send commands to device  at run time in VDCT?
what is the format of
caput? on that time
Thanks in advance
Attachment: k2400.proto
Description: k2400.proto
Keithley 2400 communication priya tiwari
Prev: Re: Processing a record a in loop David Michel
Next: RE: Processing a record a in loop Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Keithley 2400 communication priya tiwari
Next: RE: Keithley 2400 communication Mooney, Tim M.
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
