Hello users of Epics
We have several problems using 'make' in Cygwin on Windows with synApps and Epics base. When we try to use 'make support' as stated in synApps install guide, we get the following error: Epics@DEV-PC /opt/synApps_5_7/support $ make Can't open perl script "C:UsersEpicsDocumentsbase-3.14.12.3/bin/cygwin-x86/conve rtRelease.pl": No such file or directory C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:50: *** target patt ern contains no '%'. Stop. and when we try to 'make' Epics base we get the following errors: gcc -c -D_POSIX_THREADS -D_POSIX_TIMERS -DUNIX -DCYGWIN32 -O3 -Wall -m32 -D_DLL -MMD -I. -I../O.Common -I. -I../../../src/libCom/os i/os/cygwin32 -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/de fault -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../.. /src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I.. /../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libC om/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../ src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I ../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/c ygwin32 -I../../../include ../../../src/libCom/calc/postfix.c ../../../src/libCom/calc/postfix.c: In function ‘postfix’: ../../../src/libCom/calc/postfix.c:482:1: error: unrecognizable insn: } ^ (insn 537 536 538 104 (set (reg/f:SI 312) (symbol_ref:SI ("__ctype_ptr__") [flags 0x440] <var_decl 0x6ffffd389c0 _ _ctype_ptr__>)) ../../../src/libCom/calc/postfix.c:178 -1 (nil)) ../../../src/libCom/calc/postfix.c:482:1: internal compiler error: in extract_in sn, at recog.c:2154 Please submit a full bug report, with preprocessed source if appropriate. See <http://gcc.gnu.org/bugs.html> for instructions. ../../../configure/RULES_BUILD:199: recipe for target 'postfix.o' failed make[3]: *** [postfix.o] Error 1 make[3]: Leaving directory '/opt/base-3.14.12.3/src/libCom/O.cygwin-x86' ../../configure/RULES_ARCHS:63: recipe for target 'install.cygwin-x86' failed make[2]: *** [install.cygwin-x86] Error 2 make[2]: Leaving directory '/opt/base-3.14.12.3/src/libCom' ../configure/RULES_DIRS:70: recipe for target 'libCom.install' failed make[1]: *** [libCom.install] Error 2 make[1]: Leaving directory '/opt/base-3.14.12.3/src' configure/RULES_DIRS:70: recipe for target 'src.install' failed make: *** [src.install] Error 2 Thank you in advance. ----------------------------------------------------------------------------- Kind RegardsRusu Vlad Andrei T: (+004)0755.052.954 A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
