you are looking at different records:
LEBT:LEBT:PS:STH1:OPER:CurrSP
and
Please check.
Dr. Burkhard Kolb
Tel +49 6159 712667
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 | D-64291 Darmstadt | www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Dr. h.c. mult. Horst Stöcker,
Dr.-Ing. Jürgen Henschel
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Am 10.09.2014 um 10:30 schrieb [email protected]:
> Dear Ralph,
> Thanks for the comment.
>> The "cainfo" command line tool will tell you if you can connect
>> successfully, and if you have the necessary access rights. (Which you
>> should have if caput does not show errors.)
> The outuput of cainfo is
> State: connected
> Host: 10.30.0.10:5064
> Access: read, write
> Native data type: DBF_DOUBLE
> Request type: DBR_DOUBLE
> Element count: 1
>> Some records have mechanisms (like the DRVH/DRVL drive limits of the ao
>> record or the OMSL mode selection of many output records) that would
>> reject certain values written to the PV. Some fields of some record
>> types cannot be written to at all through Channel Access (see the Record
>> Reference Manual for details on that).
>> What value are you trying to write to which field of what record type?
> THis is the current setpoint of a power suplly.
> The IOC db file contains this information
> record(ai,"LEBT:PS:STH1:OPER:CurrSP"){
> field(INP,"LV:LEBT:PS:STH1:OPER:CurrSP CP")
> field(DESC,"PS EXT Voltage")
> field(DESC, "LEBT STH1 Current SP")
> I guess that I am trying to change the INP field which has no access
> permission according to the Record Reference Manual, isn't it?
> In this case how is possible that the value can be changed with the CSS GUI?
> Should have the record a VAL field?
> Sorry if they are trivial questions; but I new to EPICS.
> Zunbeltz
>> Cheers,
>> ~Ralph
- check what is caput doing zunbeltz
- Re: check what is caput doing Ralph Lange
- Re: check what is caput doing zunbeltz . izaola
Device Support Options for NI RIO Ralph Lange
<2014>
<2014>
