1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: check what is caput doing
To: "Ralph Lange" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 10 Sep 2014 10:30:53 +0200
Dear Ralph,
Thanks for the comment.
> The "cainfo" command line tool will tell you if you can connect
> successfully, and if you have the necessary access rights. (Which you
> should have if caput does not show errors.)
The outuput of cainfo is
LEBT:LEBT:PS:STH1:OPER:CurrSP
    State:            connected
    Host:             10.30.0.10:5064
    Access:           read, write
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    1
> Some records have mechanisms (like the DRVH/DRVL drive limits of the ao
> record or the OMSL mode selection of many output records) that would
> reject certain values written to the PV. Some fields of some record
> types cannot be written to at all through Channel Access (see the Record
> Reference Manual for details on that).
> What value are you trying to write to which field of what record type?
THis is the current setpoint of a power suplly.
The IOC db file contains this information
record(ai,"LEBT:PS:STH1:OPER:CurrSP"){
  field(INP,"LV:LEBT:PS:STH1:OPER:CurrSP CP")
  field(DESC,"PS EXT Voltage")
  field(DESC, "LEBT STH1 Current SP")
I guess that I am trying to change the INP field which has no access
permission according to the Record Reference Manual, isn't it?
In this case how is possible that the value can be changed with the CSS GUI?
Should have the record a VAL field?
Sorry if they are trivial questions; but I new to EPICS.
Zunbeltz
> Cheers,
> ~Ralph
Re: check what is caput doing Burkhard Kolb
Re: check what is caput doing Ralph Lange
check what is caput doing zunbeltz
Prev: Re: check what is caput doing Ralph Lange
Next: Device Support Options for NI RIO Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: check what is caput doing Burkhard Kolb
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
