Hello again, EPICS users,
I managed to connect the 2 PCs, with your help, which is greatly appreciated. It was an issues with the firewall on linux. Now, I want to be able to create an IOC for a Stanford Research DG645 to be able to remotely monitor and control data. I unpacked synApps, modified RELEASE to point to EPICS and synApps top folder but then I try to use "mingw32-make.exe release" it says: C:\Users\Epics\D C:\Users\Epics\Documents\synApps\synApps_5_7\support>mingw32-make.exe release C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/CONFIG:100: C:\Users\Epics\Doc uments\synApps\synApps_5_7\support: Permission denied C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target 'C:\User s\Epics\Documents\synApps\synApps_5_7\support' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target '-includ e' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target 'C:\User s\Epics\Documents\synApps\synApps_5_7\support' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target '-includ e' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target 'C:\User s\Epics\Documents\synApps\synApps_5_7\support' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target '-includ e' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target 'C:\User s\Epics\Documents\synApps\synApps_5_7\support' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target '-includ e' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target 'C:\User s\Epics\Documents\synApps\synApps_5_7\support' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target '-includ e' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target 'C:\User s\Epics\Documents\synApps\synApps_5_7\support' given more than once in the same rule. C:\Users\Epics\Documents\base-3.14.12.3/configure/RULES_DIRS:69: target '-includ e' given more than on C:\Users\Epics\Documents\synApps\synApps_5_7\support> And it just goes on in a loop until I cancel it ----------------------------------------------------------------------------- Kind RegardsRusu Vlad Andrei T: (+004)0755.052.954 A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
