1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: scalcout with streamDevice - request for guidance and example
To: <[email protected]>
Date: Thu, 4 Sep 2014 11:43:57 +0000
That file does not exist in our streamDevice module, so the issue seems to be with the build of that module.  Apparently there are some optional dependency settings in the release file which change the build which the module owner here was unaware of.
Thanks Marty,
Linda
-----Original Message-----
Sent: 04 September 2014 12:17
To: [email protected]
Subject: Re: scalcout with streamDevice - request for guidance and example
Hi Linda,
Looks like the scaclcout for streamDevice is defined in the top streamDevice dbd area rather than in the calc support.
streamApp.dbd:device(scalcout,CONSTANT,devsCalcoutSoft,"Soft Channel")
streamApp.dbd:device(scalcout,INST_IO,devscalcoutStream,"stream")
streamSynApps.dbd:device(scalcout,INST_IO,devscalcoutStream,"stream")
So it is likely that in your Makefile you will need to include the dbd streamSynApps.dbd
Marty
On 09/04/2014 05:24 AM, [email protected] wrote:
> I am trying to use an scalcout record with a stream device protocol
> and  I need to capture a string value  in one of the string fields.  I
> already have calcout records working to do an equivalent job to
> capture a numeric field.  The protocol makes use of the field name syntax to access the record letter fields.
> The stream device online manual states scalcout  records are allowed
> since v2-1 and work since 2-6-1 of calc module, the IOC is built for
> linux-x86 with streamDevice v2-5dls2, v3-1 of calc, with v2-8-1 of
> sscan and v1-8dls2-9 of genSub under EPICS R3.14.11 and I have added
> dbd and library entries to the Makefile for these modules.
> I copied my functioning calcout record (with DTYP stream), changed it
> to scalcout and edited it to call the protocol.
> dbLoadRecords results in the following error message for the scalcout records:
> Can't set "TS-VA-TURBO-03:GET:PARAM:DATATYPE4.DTYP" to "stream"
> Examining the built dbd file I can find
> device(calcout,CONSTANT,devCalcoutSoft,"Soft Channel")
> device(calcout,CONSTANT,devCalcoutSoftCallback,"Async Soft Channel")
> device(calcout,INST_IO,devcalcoutStream,"stream")
> It appears that only Soft Channel DTYP is available to scalcout.  Was
> it wrong of me to expect DTYP stream to be available or am I missing
> something from the IOC or module builds?
> Is there a working example of scalcout and stream being used together I can look at?
> Thanks,
> Linda
> This e-mail and any attachments may contain confidential, copyright
> and or privileged material, and are for the use of the intended
> addressee only. If you are not the intended addressee or an authorised
> recipient of the addressee please notify us of receipt by returning
> the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual
> and not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for
> any damage which you may sustain as a result of software viruses which
> may be transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in
> England and Wales with its registered office at Diamond House, Harwell
> Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United
> Kingdom
RE: scalcout with streamDevice - request for guidance and example Mooney, Tim M.
scalcout with streamDevice - request for guidance and example Linda.Pratt
Re: scalcout with streamDevice - request for guidance and example Martin L. Smith
Prev: Re: scalcout with streamDevice - request for guidance and example Martin L. Smith
Next: RE: SNL syntax highlight for text editors Mazanec Tomáš
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: scalcout with streamDevice - request for guidance and example Mooney, Tim M.
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
