1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Processing a record a in loop
To: <[email protected]>
Date: Wed, 3 Sep 2014 11:26:07 -0500
On 09/03/2014 10:21 AM, Pearson, Matthew R. wrote:
> You can also set the TPRO field to 1 in that record, which will cause
> a string to be printed on the IOC shell whenever that record is
> processed (although it might just do it at the SCAN rate, and not
> reflect any ongoing processing. Not sure).
If a record with TPRO set is already active (PACT set) when it is asked
to process the message printed will say "Active"; if processing is
disabled with the SDIS/DISA/DISV mechanism the message will say
"Disabled". The normal "Process" message is printed immediately before
the record's process() routine is called.
Note that setting TPRO on one record also triggers messages from any
down-stream records that get processed synchronously through DB links
from that record — the downstream records must be in the same lock-set,
and get processed before the process() routine from the TPRO record has
returned.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Processing a record a in loop David Michel
RE: Processing a record a in loop Mark Rivers
Re: Processing a record a in loop David Michel
Re: Processing a record a in loop Pearson, Matthew R.
Prev: Re: Processing a record a in loop Pearson, Matthew R.
Next: RE: synApps_5_7 build error on Windows 8.1 x64 freddie.akeroyd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Processing a record a in loop Eric Norum
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
