> Though all I can see from it is:
> [timestamp] [ip:port] read 3
> [timestamp] [ip:port] write 5
That is because you have not set the ASYN_TRACEIO_ESCAPE in asynTraceIO
Here is how to do it in your startup script any time after the asyn port is created:
#This sets ASYN_TRACEIO_ESCAPE(=2)
asynSetTraceIOMask(“myPort”, 0, 2)
# This sets ASYN_TRACE_ERROR (=1) and ASYN_TRACEIO_DRIVER (=8)
asynSetTraceMask(“myPort”,0,9)
Once you do that you should see that actual data being sent and received as well.
Sent: Wednesday, September 03, 2014 10:09 AM
To: Mark Rivers
Cc: EPICS mailing list
Subject: Re: Processing a record a in loop
Hi Mark,
>I don’t think you need to do anything to guarantee that you will not send a request until the first one returned; that is the way asynchronous record processing with StreamDevice works.
Fair enough. To be honest, I wasn't entirely sure of that thus me trying to level my doubts.
>Are you aware of the asynTrace facility?
No, I wasn't - thanks for that! Though all I can see from it is:
So not learning much from this
On 3 September 2014 15:14, Mark Rivers <[email protected]> wrote:
> So no evidence... but that's why I wanted to try only sending a request after the first one returned to see if that fixes it.
works. Once the record sends a request the record is busy (PACT=1) until it either gets a response or times out. If I understand what you are worried about it is that EPICS could send a second request (“Done?”) before the first one returns a response or
times out. But that should not happen. Thus if your record is processing with 0.1 second and the response takes 0.2 second then it will not process the record again until the previous processing is complete.
Are you aware of the asynTrace facility? I would highly recommend that you set the ASYN_TRACEIO_DRIVER and ASYN_TRACEIO_ESCAPE bits on the underlying asyn port. That way you will
see all of the communication to and from the device, including time stamps.
> Not sure what I would learn from using asyn directly ? Are you thinking of ruling out (or not!) streamdevice as the cause of the issue?
Yes, but as I said I think that you will see the same behavior.
Sent: Wednesday, September 03, 2014 9:02 AM
To: Mark Rivers
Hi David,
Good point about the buffer filling up vs. restarting the IOC... The buffer being full was simply a speculation of mine as to what might be going on... but you're right, restarting
the IOC would not be affecting this of course. So no evidence... but that's why I wanted to try only sending a request after the first one returned to see if that fixes it.
I think I've managed to do this using the EVENT record... but the problem still persists, so it might not be the device's buffer after all...
p.s. when I say "custom"... I mean a non commercial product made by 3rd party suppliers... nothing that I have direct control of. Just trying to work things out before contacting
them.
Dr. David Michel
Address: 8 Viking Drive, Didcot, OX11 9RD, Oxfordshire
Mobile: 0789 670 98 01 - Home: 0123 581 46 93
On 3 September 2014 13:39, Mark Rivers <[email protected]> wrote:
Hi David,
In your original message you said:
> Problem is that after a while (~ couple of hours), the device's buffer fills up and doesn't reply anymore.
But in your last message you said:
> The only remedy is to kill and restart the IOC.
That does not really make sense to me. If the device buffer is full why does restarting the IOC fix the problem? How does the device know that you did that?
What is the evidence that a buffer is filling up on the device?
You could use an asyn record to do a write/read operation to the device, rather than streamDevice, for testing. Just put the "done?" in the AOUT field and set the asyn record to periodically process at 1 second. Do you get the same behavior? I suspect you
will, but it would be interesting to find out.
If it's a custom device can you fix the buffer problem on it if that is indeed the problem?
Sent: Wednesday, September 03, 2014 7:24 AM
To: Mark Rivers
Adjusting the time is the first thing I tried of course... but although the typical response time is very short, i.e. a couple of ms, after a while, I get the "No reply from device within x ms" even with a timeout set to something ridiculous like 10000ms
The protocol is very simple:
are_you_done {
out "done?";
in "%b";
used with a BI record.
I just tried to use an EVENT record: i.e. FWDLINK the BI record to the EVENT record and set the SCAN field of the BI record to that event... but same error eventually comes up.
David
On 3 September 2014 13:08, Mark Rivers <[email protected]<mailto:[email protected]>>
wrote:
What is the maximum/typical time between when you send a query and receive a response?
You should be able to set the timeout to a value just longer than the maximum and then you can process the record with any fixed rate (1 seconds, 10 seconds, etc.). The record will be busy (PACT=1) if the next scan interval happens before the reply from the
previous one. So it will not keep sending query messages, it will wait for a reply before proceeding.
What does your protocol file look like? Is it a single query per response, etc.?
[email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>]
on behalf of David Michel [[email protected]<mailto:[email protected]>]
Sent: Wednesday, September 03, 2014 6:02 AM
To: EPICS mailing list
Subject: Processing a record a in loop
Hi All,
I'm using StreamDevice to talk to a custom device that doesn't support I/O interrupt so one has to keep sending commands to it to get status information.
Problem is that after a while (~ couple of hours), the device's buffer fills up and doesn't reply anymore. Increasing the ReplyTimeOut improves things slightly, but the problem still eventually occurs.
One potential solution would be to send the next command only once the previous one has returned in a loop (instead of using a set frequency).
Making the record FWD link to itself doesn't seem to do it... I started something using purely database trickery with a FANOUT record set with a fixed SCAN field and disabling it depending on whether the streamdevice record has finished processing or not...
but it's getting messy
Is there an elegant way of doing this?
David
- Processing a record a in loop David Michel
- RE: Processing a record a in loop Mark Rivers
- Re: Processing a record a in loop David Michel
Re: Processing a record a in loop Pearson, Matthew R.
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
