Hello all, Yes, it is true that EPICS_HOST_ARCH should be set in the environment which I do. Now correct me If I am wrong, but I was under the impression that the makeSupport perl script in ../aysn-4-23/bin/<arch>/ creates the device support directories i.e the configure/release files and so on and then you run makeBase.pl to create the application. This is where my problem is, because when I run makeSupport.pl, I get the error mentioned in the first email. I might be wrong since I am fairly new to the EPICS community.
Thank you
Regards, Ali ------------------------------------------------------
Alireza Panna University of Maryland, College Park On Tue, Sep 2, 2014 at 7:15 AM, Mark Rivers <[email protected]> wrote: Ralph is right, only ASYN should be defined in configure/RELEASE, EPICS_HOST_ARCH should be defined as an environment variable.
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
