1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Problem with EPICS IOC on Windows x64
To: Vlad Andrei Rusu <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 28 Aug 2014 13:20:48 +0000
Can you send the complete output when you run the IOC and try to execute the st.cmd?
If you cd to the ioc directory then you would issue a command like the following:
..\..\bin\windows-x64\myApp st.cmd
For mingw windows-x64 will need to be replaced with a different ARCH string, and myApp is of course the name of your application.
For medm the directory
extensions/src/medm/medm
contains files like fonts.alias.sun, etc.  I normally take the fonts.alias.sun and paste those font aliases into a fonts.alias file in the X11 font directory.  If you are running medm on Windows then the mechanism to do that will depend on your X11 server.  On Exceed, for example, it is done with the XConfig program, using a GUI to import the font aliases.
From: [email protected] [[email protected]] on behalf of Vlad Andrei Rusu [[email protected]]
Sent: Thursday, August 28, 2014 8:02 AM
To: [email protected]
Subject: Problem with EPICS IOC on Windows x64
Hello EPICS users.
We are trying to run an IOC on Windows x64 using mingw, and we encountered some problems, as the title states. First of all, we are having a problem with the IOC .dbd file, the IOC initializes but from what we understood, st.cmd is not running, when we are trying to run just this file, it gives us the error:
# is not a recognized command.
Perl is installed and in Path,
Mingw is installed and in Path.
We can enter epics shell, the commands work, we can open the .dbd and .db device in VDCT.
But when we use "dbl" it says:"No database loaded".
We were able to run MEDM as well, and here comes the second problem, how can we install the fonts required by MEDM? On the EPICS webpage, the link towards downloads it's just a .txt file, we tried to use save link as but it did not work.
Kind Regards
Rusu Vlad Andrei & Bertrand de Boisdeffre
E: [email protected]<mailto:[email protected]> & [email protected]<mailto:[email protected]>
Problem with EPICS IOC on Windows x64 Vlad Andrei Rusu
Prev: Problem with EPICS IOC on Windows x64 Vlad Andrei Rusu
Next: RE: Problem with EPICS IOC on Windows x64 Mazanec Tomáš
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
