1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: synApps record
To: [email protected]
Date: Wed, 27 Aug 2014 10:41:35 +0530
Thanks for suggestion
when i added dbd file in make/src file then i got the error.................
/usr/bin/ld: tmy_registerRecordDeviceDriver.o: undefined reference to symbol 'pvar_int_sscanRecordViewPos'
/usr/bin/ld: note: 'pvar_int_sscanRecordViewPos' is defined in DSO /home/srk/epics/synApps_5_7/support/sscan-2-9/lib/linux-x86/libsscan.so so try adding it to the linker command line
/home/srk/epics/synApps_5_7/support/sscan-2-9/lib/linux-x86/libsscan.so: could not read symbols: Invalid operation
collect2: error: ld returned 1 exit status
make[3]: *** [tmy] Error 1
make[3]: Leaving directory `/home/srk/tt/tmyApp/src/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/home/srk/tt/tmyApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/home/srk/tt/tmyApp'
make: *** [tmyApp.install] Error 2
please see make file and config/release .
On Tue, Aug 26, 2014 at 7:22 PM, Mooney, Tim M. <[email protected]> wrote:
Hi Priya,
If you've built synApps, there should be a dbd file with all the records from base and synApps in the xxx/dbd directory.  The synApps Makefile is sort of complicated, because it tries to build everything and also tries to not build modules that have been commented out of configure/RELEASE, but it's an example of what you can use in your own application's Makefile.  In fact, usually I start with a copy of the xxx module, and modify it to make my application.
Tim Mooney ([email protected]) (630)252-5417
Software Services Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] [[email protected]] on behalf of priya tiwari [[email protected]]
Sent: Tuesday, August 26, 2014 1:03 AM
Subject: synApps record
Hello
          I am trying to use other records of synApps which is not in VDCT for eg. scalcout,transform,asyn etc.I have installed synApps_5_7 in EPICS folder , then How to use synApps record in my VDCT application?
What changes are required to be made in my own directory?plz help me
                            Thanks in advance....
Attachment: RELEASE
Description: Binary data
Attachment: Makefile
RE: synApps record Mark Rivers
synApps record priya tiwari
RE: synApps record Mooney, Tim M.
Prev: RE: ePID deadband on output Mooney, Tim M.
Next: RE: synApps record Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: synApps record Mooney, Tim M.
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
