HI Priya,
You have to define a dbd file that includes all the record and menu types you need in your application, and then point VDCT at that. Often, this is just a case
of putting statements like:
DBD += <name>.dbd
<name>_DBD += <file1>.dbd <file2>.dbd ...
… into the Makefile in the application src directory. These then just get built into a single file called <name>.dbd in the dbd directory, and you can point
your version of VDCT at that. However, you do have to do an initial make to create the file before you can run vdct.
You can also hand craft a default site-wide .dbd and use that.
More information is in the manual:
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node5.html#SECTION00566000000000000000
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
Sent: 26 August 2014 07:04
To: [email protected]
Subject: synApps record
I am trying to use other records of synApps which is not in VDCT for eg. scalcout,transform,asyn etc.I have installed synApps_5_7 in EPICS folder , then How to use synApps record in my VDCT application?
What changes are required to be made in my own directory?plz help me
Thanks in advance....
