1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ePID deadband on output
To: "Bruce Hill" <[email protected]>
Cc: Core-Talk <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 25 Aug 2014 15:38:21 -0700 (PDT)
But the "I" in the PID is already an IIR filter.
Putting additional filter inside a feedback loop is tricky.  Too short a
time constant make the filter ineffective, too long a time constant makes
the loop unstable.
The motor itself could be another integrator. Having 2 integrators and
addition phase lag from an IIR filter in a feedback loop is not a good
idea.
Dead band with hysteresis is much simpler.
Ken
> We have a similar PID controlling a stepper motor.
> Since we don't have a amplifier for the stepper motor I actually
> think we probably could allow the motor deadband to handle this,
> but the "owner" of the stepper motor is more comfortable with
> us shutting it off while we're close to the target position.
> Instead of using time within the deadband to turn ours on and
> off, we use an IIR filter similar to the smoothing algorithm in
> the AI record with an OFF threshold which can be quite small
> so we don't shut off till we're centered, and an ON threshold
> which turns the PID back on when it drifts too far.
> Time still enters into this calculation via the time constant of
> the IIR filter factor, but you can ensure your PID gets closer
> Regards,
> - Bruce
> On 08/25/2014 10:24 AM, Pearson, Matthew R. wrote:
>> Hi Folks,
>> I initially tried setting MDEL on the ai record that provides the
>> pressure readback (which is the input to the ePID). I found that the
>> ePID only controlled the output (the stepper motor) so that the pressure
>> sat at the low or high limit of the MDEL, depending on which side it was
>> approached from. So I needed some time factor to take the settling time
>> into account (to reach the center of the deadband).
>> The motor record has deadbands for the monitors (MDEL and ADEL), but not
>> on the input (except for the NTM logic to deal with backlash
>> compensation).
>> On Aug 25, 2014, at 11:14 AM, "Dalesio, Leo" <[email protected]> wrote:
>>> Time can be captured in the integral term of the ePID. If that term
>>> continues to push the change up, it will exceed the position.
>>> Is that the argument for putting it in the ePID? We don't integrate the
>>> error if it is inside the deadband? Is this the only term that does not
>>> care inside a given deadband?
>> The output would be completely off (FBON=Off) if we have been within the
>> deadband for N seconds. It would only turn on again (and reset the
>> timer) if it drifts outside the deadband.
>> The idea is that the controlled variable may sit within the deadband for
>> minutes or even hours without any further control needed (which in my
>> case means switching a stepper motor amplifier on and off).
>> Cheers,
>> Matt
>>> This looks like a good discussion for either the code-a-thon or a side
>>> meeting at the EPICS meeting.
>>> ________________________________________
>>> From: Mark Rivers [[email protected]]
>>> Sent: Monday, August 25, 2014 11:03 AM
>>> To: Dalesio, Leo; 'Benjamin Franksen'; [email protected];
>>> 'Core-Talk'
>>> Subject: RE: ePID deadband on output
>>> That's an interesting point.
>>> The motor record already has a deadband.  Matt, did you try just using
>>> the deadband on the motor record?
>>> I don't think it has the concept of the time inside the deadband
>>> though.
>>> Mark
>>> -----Original Message-----
>>> From: Dalesio, Leo [mailto:[email protected]]
>>> Sent: Monday, August 25, 2014 9:51 AM
>>> To: Mark Rivers; 'Benjamin Franksen'; [email protected];
>>> 'Core-Talk'
>>> Does the deadband belong on the ePID or the motor record?
>>> It seems like more of an output issue - not an algorithm issue.
>>> Bob
>>> From: [email protected] [[email protected]] on
>>> behalf of Mark Rivers [[email protected]]
>>> Sent: Monday, August 25, 2014 10:39 AM
>>> To: 'Benjamin Franksen'; [email protected]; 'Core-Talk'
>>> Sorry for the delay in replying, this seems good to me as well.
>>> Mark
>>> [mailto:[email protected]] On Behalf Of Benjamin Franksen
>>> Sent: Monday, August 25, 2014 5:14 AM
>>> To: [email protected]; 'Core-Talk'
>>> [cross-posting to core-talk]
>>> On Thursday 14 August 2014 18:13:15 Pearson, Matthew R. wrote:
>>>> I'm using the ePID record to control a needle valve filling a cryostat
>>>> with helium. The needle valve is controlled by a stepper motor. The
>>>> ePID is giving good results, but I found the need for a deadband on
>>>> the PID output. This is to avoid continually driving the motor to and
>>>> fro by just a few steps. I implemented it via set of database
>>>> records, and included a timer to tell me how long the helium pressure
>>>> has been within a deadband, and then I disable the PID output (by
>>>> setting FBON).
>>>> However, I'm wondering if's a common enough use-case to be implemented
>>>> in the ePID record. It would mean adding some additional fields,
>>>> something like:
>>>> DBS - the deadband size
>>>> DBTS - settling time in the deadband (to avoid sitting on the edge of
>>>> the deadband) DBT - time in seconds since we entered the deadband
>>>> window
>>>> DBIN - binary flag to indicate we are in the deadband
>>>> If ABS(CVAL-VAL)<=DBS, and DBT>=DBTS seconds, then disable FBON.
>>>> If ABS(CVAL-VAL)>DBS then reset DBTS and enable FBON.
>>>> And to maintain current behavior, keep DBS=0 (the default).
>>>> The database version is working fine, but it's quite a few records and
>>>> I suspect it would be much simpler in the soft device support.
>>> Sounds like a pretty good idea to me.
>>> Cheers
>>> Ben
>>> "Make it so they have to reboot after every typo." ― Scott Adams
>>> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
>>> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
>>> Forschungszentren e.V.
>>> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch,
>>> stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
>>> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas
>>> Frederking
>>> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
>>> Postadresse:
>>> Hahn-Meitner-Platz 1
>>> D-14109 Berlin
>>> http://www.helmholtz-berlin.de
> Bruce Hill
> Member Technical Staff
> SLAC National Accelerator Lab
> 2575 Sand Hill Road M/S 10
> Menlo Park, CA  94025
"The beaver told the rabbit as they stared at Hoover Dam. 'No, I didn't
build it myself. But it's based on an idea of mine.'"
Charles Townes
Re: ePID deadband on output Bruce Hill
ePID deadband on output Pearson, Matthew R.
Re: ePID deadband on output Benjamin Franksen
RE: ePID deadband on output Mark Rivers
RE: ePID deadband on output Dalesio, Leo
Re: ePID deadband on output Pearson, Matthew R.
Prev: Re: ePID deadband on output Bruce Hill
Next: Re: ePID deadband on output Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
