1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Windows installer error - bcastEnvChange.exe
To: "Anderson, Janet B." <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 16 Aug 2014 12:51:22 -0500
I've definitely got the .NET framework installed. It appears I have several versions, including 1.0, 1.1, 2.0 SP2, 3.0 SP2, 3.5 SP1 and 4. I don't see anything in Add or Remove Programs about Microsoft Windows Installer. Is there any kind of install log that this produces? Does the Event Viewer assertion that bcastEnvChange.exe failed make sense?
Ryan
On 8/15/2014 11:34 AM, Anderson, Janet B. wrote:
Hi Ryan,
The 1.44 msi files have  Microsoft Window Installer 4.5 as a prerequisite but it should be automatically  downloaded and installed  during the 1.44 installation if it is not found.  The 1.44 msi files were created from a setup project using Visual Studio 2013 and It is possible that Microsoft .NET Framework is a prerequisite for all setup projects created with Visual Studio.  Do you have a version of Microsoft .NET Framework installed?
Janet
From: [email protected] [[email protected]] on behalf of Ryan Pierce [[email protected]]
Sent: Friday, August 15, 2014 12:15 AM
To: [email protected]
Subject: Windows installer error - bcastEnvChange.exe
I'm trying to install EPICSWindowsTools1.44-x86 for the first time on a
WinXP system. The MSI install package failed near the end of the install
and uninstalled everything. Looking at the system event log, I see:
Product: EPICS Windows Tools -- Error 1721. There is a problem with this
Windows Installer package. A program required for this install to
complete could not be run. Contact your support personnel or package
vendor. Action: _C64BF50F_FECC_4987_9245_67049C9EB83D, location:
C:\Program Files\EPICS Windows Tools\SetupFiles\bcastEnvChange.exe,
command: /Install
I had previously installed VirtualLinacSetup (which is from 2004? Is
that the latest version?) which was successful, but starting it was
problematic without medm, leading me to realize that EPICSWindowsTools
was required. I uninstalled VirtualLinacSetup and rebooted. I still get
the same error.
I'm sure my account has administrator access. I'm trying to install
using the default parameters. I don't have Exceed installed. (I'm
guessing medm needs an X server, but I can install Xming later, yes?)
Any thoughts?
Ryan
Windows installer error - bcastEnvChange.exe Ryan Pierce
RE: Windows installer error - bcastEnvChange.exe Anderson, Janet B.
Prev: RE: Areadetector IOC for Pilatus Mark Rivers
Next: Re: Recommended Control HWs for High Voltage Platform Jeong Han Lee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Windows installer error - bcastEnvChange.exe Anderson, Janet B.
Next: Problem with creating an array of Long with aSub record David Michel
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
