But as far as I can tell, Kellee should be able to use ai records as the placeholders — and then things should work.Oops, my bad, I mis-read the dbCommon.dbd file, UDF /is/ writable, but writing to the UDF field of an ao record has little effect:
tux% caput anj:ao.UDF 1 Old : anj:ao.UDF 0 New : anj:ao.UDF 0
I think what happened is that the record processed as a result of the put [since UDF is marked pp(TRUE)], and the process routine overrode the 1 that I set the UDF field to with a 0.
I /can/ set UDF to make an ai record go into UDF/INVALID alarm, but that doesn't work on an ao record, where I have to write NaN to the VAL field instead (the UDF field acts more like an output for an ao record).
My apologies to Andrew Starritt who was evidently using an ai record, whereas Kellee and I were both using ao records.
- How to tag soft channels as undefined/disconnected Kellee Summers
- RE: How to tag soft channels as undefined/disconnected Lionberger, Carl A.
- Re: How to tag soft channels as undefined/disconnected Kellee Summers
- RE: How to tag soft channels as undefined/disconnected Andrew C. Starritt
- Re: How to tag soft channels as undefined/disconnected Andrew Johnson
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
