1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Help with building CSS using cs-studio-3.3.x
To: "<[email protected]> " <[email protected]>
Cc: "<[email protected]>" <[email protected]>, "<[email protected]>" <[email protected]>
Date: Mon, 11 Aug 2014 13:15:25 +0000
Hi:
The build is being transitioned to Maven, but I have not been able to get that to complete for SNS since the recent EPICS meeting. In the fullness of time, the idea is that it should work and the docbook would then be updated to describe it, but right now it's in an intermediate state.
What works for me is still the approach that Matt describes, import the plugins as before into the IDE. To be able to do that, you may want to delete the core/.project and applications/.project files because they tend to hide the underlying plugin .project files.
Note that the 'master' branch now builds with Eclipse 4.4, the current release of Eclipse, while the 3.x branch uses Eclipse 3.7.2 as a target.
Kay
On Aug 11, 2014, at 5:05 AM, <[email protected]>
 wrote:
> Hi,
> There are instructions on building CSS, these are available in the CSS Doc Book:
> http://cs-studio.sourceforge.net/docbook/ch04.html#sec_tycho_build
> I have used them to build a product off the master branch, with a couple of changes to poms and feature definitions.
> When importing Plugins into Eclipse, the 'old fashioned' method of importing Projects should work as long as you ensure that 'Search for nested projects' is ticked. Note that I'm using Eclipse Luna as my development IDE, you should also be able to use this as long as you select an appropriate target platform to build the 3.3.x sources against.
> Regards,
> Matt
> From: [email protected] [[email protected]]
> Sent: 11 August 2014 04:30
> To: [email protected]
> Subject: Help with building CSS using cs-studio-3.3.x
> Hi,
> We have been building our CSS with cs-studio-3.2. We imported plugs and features into Eclipse or we used ant to do headless build. We are investigating migrating to cs-studio-3.3.x branch which uses mavern. I have tried a few things:
> - I could not import the plugins and features straight to Eclipse anymore, so I tried 'mvn -npr eclipse:eclipse’. That failed with errors
> - I tried 'mvn compile’ and that failed with errors too.
> I’m wondering if there is any step by step instruction on how to build CSS using maven with cs-studio-3.3.x, both with Eclipse and headless.
> Thanks,
> Xinyu WU
> ASKAP Computing
> Australia Telescope National Facility
> CSIRO Astronomy and Space Science
> phone: +61 2 9372 4727
> postal: PO Box 76 Epping, NSW. 1710
Help with building CSS using cs-studio-3.3.x Xinyu.Wu
RE: Help with building CSS using cs-studio-3.3.x matthew.furseman
Prev: RE: Help with building CSS using cs-studio-3.3.x matthew.furseman
Next: Launching CS-Studio BOY screens tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
