make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[4]: Entering directory `/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e/vxStatsApp/Db/O.linux-x86' Inflating database from ../vxStats-template.substitutions using local rule msi -S../vxStats-template.substitutions > vxStats-template.db </dev/null /bin/sh: msi: command not found make[4]: *** [../O.Common/vxStats-template.db] Error 127 make[4]: Leaving directory `/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e/vxStatsApp/Db/O.linux-x86' make[3]: *** [install.linux-x86] Error 2 make[3]: Leaving directory `/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e/vxStatsApp/Db' make[2]: *** [Db.install] Error 2 make[2]: Leaving directory `/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e/vxStatsApp' make[1]: *** [vxStatsApp.install] Error 2 make[1]: Leaving directory `/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e' make: *** [/home/srk/epics/synApps/synApps_5_3/support/vxStats/1-7-2e.install] Error 2 srk@localhost:~/epics/synApps/synApps_5_3/support/config$ :Error 127 bash: :Error: command not found...
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
