1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: error of beacon
Cc: Azra Jabeen <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 07 Aug 2014 08:08:12 -0600
On 8/5/2014 11:32 AM, Andrew Johnson wrote:
On 08/05/2014 11:58 AM, Hill, Jeff wrote:
../online_notify.c: CA beacon (send to "192.168.1.143:5065") error was
"Connection refused
The host in question might be returning an ICMP port unreachable
response. Typically, ICMP replies are not sent in response to a
broadcast message by a well behaved IP stack, but if there was an
explicit unicast IP in in the CA address list on this particular IOC
(with the annoying messages), then an ICMP response when no CA repeater
daemon is listening from this particular host (192.168.1.143) is likely
to occur. Another possibility might be problems with the route from the
IOC (with the annoying messages) to this particular host (192.168.1.143).
We need to add code to suppress this message after it has been output a
few times. The APS has operational IOCs for which we cannot see the
console history because of floods from this error report.
Our network guys have developed ways of tracing where the ICMP messages
come from and can usually reconfigure the devices we trace them to to
end them, but once the beacon error messages from online_notify.c have
started we have to reboot the IOCs to stop them again (not always
possible while we're running).
If you want to take a look at fixing the code I'd be happy to help out
with testing, but if you don't have time I will be working on this and
committing changes to the 3.14 branch to severely reduce the frequency
of these error messages.
I'm pretty sure this is related to the new TCP/IP stack in a recent version of vxWorks (I believe the change was in 6.5). Our IOCs will occasionally receive the connection refused message in response to a broadcast. A soft IOC running on linux, printed this connection refused message exactly twice. All of our 6.8 IOCs repeat this message until reboot, AND do not send out beacons, until the reboot. However, it is possible to send out a broadcast from the IOC (e.g., ping the broadcast address). I haven't had time to test anything, but I think the solution will be either to send the broadcast anyway, and suppress the message after the first few, or to actually setup a new UDP socket after receiving this message. Although, these are really just workarounds, perhaps we should take this up with WindRiver (I don't see any reason why a local UDP broadcast socket should need to be invalidated because of an ICMP response from a misbehaving device).
Scott Baily
AOT-IC, MS H820
Los Alamos National Laboratory
Los Alamos, NM 87545
ph: (505) 606-2260
error of beacon Azra Jabeen
RE: error of beacon Hill, Jeff
Re: error of beacon Andrew Johnson
Prev: RE: USB asyn driver Mark Rivers
Next: Problem linking Mclennan stepper motor libraries into x86 IOC app Peter Linardakis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: error of beacon Andrew Johnson
Next: Re: error of beacon Hu, Yong
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
