1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Recommended Control HWs for High Voltage Platform
To: "Jeong Han Lee" <[email protected]>
Date: Tue, 5 Aug 2014 07:32:51 +0800
hi, Jeong Han Lee:
If your power supply has only analog interface, you can consider about using PLC to control power supply. For example, use one Yokogawa PLC on ground level platform (if you use RTOS module, dedicated soft IOC can be ignored), several PLCs on other high voltage platform, PLCs can communicate by FA-LINK fiber. Surely you can choose other brand of PLCs.
Best wishes
Geyang 2014-08-05
##############on 2014-07-31, [email protected] wrote:###############
Dear All,
   We are designing a control system, which is, of course, based on
EPICS, for ECR Ion Source. There are three electrical potentials present
in our configuration. The first one is definitely the ground, the second
is at 45kV, and the other is at 75kV above the ground.
   All devices and equipment, HV controller, vacuum, and so on, which we
want to monitor, are located at each HV potential.
   A naive thought, which I have right now, is that MOXA NPort 56XX,
Ethernet Switch with Fiber Optic links, and EPICS IOC running on Linux
Platform should be enough.
   Do you have any example which I can follow within EPICS collaboration?
   Any suggestions and recommendation about HWs, designs, and others are
welcome always.
   Han
Jeong Han Lee, Dr.rer.nat.
Accelerator Systems Division
Rare Isotope Science Project
Institute for Basic Science
Daejeon, South Korea
tel  : +82-42-878-8733
fax  : +82-42-878-8799
Recommended Control HWs for High Voltage Platform Jeong Han Lee
Prev: Building LabCA for MATLAB Nicolas Strauss
Next: Greetings 신호철
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Recommended Control HWs for High Voltage Platform Jeong Han Lee
Next: New version of LabVIEW-EPICS-interface CA Lab 1.5.0.5 - Events are working at Linux again Carsten Winkler
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
