1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: 回复:epicsqt on arm board
To: Hansen <[email protected]>, EPICS mailing list <[email protected]>
Date: Thu, 31 Jul 2014 22:28:59 -0700
Hansen,
We need more information:
Which board are you using?
What OS?
Did you cross compile with Qt creator?
If so which toolchain and which version of Qt are you using?
The problem you have seem to be coming from your network configuration though or your EPICS environment.
How many  network interfaces to you have?
What about your EPICS environment (env | grep EPICS )?
Emmanuel
To: [email protected]; [email protected]
Subject: 回复:epicsqt on arm board
Date: Fri, 1 Aug 2014 10:47:40 +0800
Hi all,
I think it's the problem that run caclient and IOC on the same board, any document introduce how to implement it?
when I run epicsqt app , always got such message:
error sending registration message to CA repeater daemon was "Network is unreachable"
Thank you if anybody can give me some help, I will appreciate it.
------------------ 原始邮件 ------------------
发件人: "我自己的邮箱";<[email protected]>;
发送时间: 2014年7月31日(星期四) 晚上9:03
收件人: "Hansen"<[email protected]>; "tech-talk"<[email protected]>;
主题: Re:epicsqt on arm board
Hi all,
I nearly succeed in playing epicsqt on arm board.
when I put  epicsqt app with IOC on the same board, the epicsqt app can't detect the pv change, but when I put the epicsqt app on another arm board, the epicsqt app can automatically detect the pv change.
anybody has idea about it?
------------------ Original ------------------
Date:  Tue, Jul 29, 2014 08:58 PM
To:  "tech-talk"<[email protected]>;
Subject:  epicsqt on arm board
Anybody compile epicsqt on arm using cross compiler?
=?gb18030?b?u9i4tKO6IFJFOiC72Li0o7plcGljc3F0IG9uIGFy?==?gb18030?b?bSBib2FyZA==?= =?gb18030?b?SGFuc2Vu?=
epicsqt on arm board Hansen
Re:epicsqt on arm board =?gb18030?b?SGFuc2Vu?=
=?gb18030?b?u9i4tKO6ZXBpY3NxdCBvbiBhcm0gYm9hcmQ=?= =?gb18030?b?SGFuc2Vu?=
Prev: =?gb18030?b?u9i4tKO6ZXBpY3NxdCBvbiBhcm0gYm9hcmQ=?= =?gb18030?b?SGFuc2Vu?=
Next: New version of LabVIEW-EPICS-interface CA Lab 1.5.0.5 - Events are working at Linux again Carsten Winkler
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: =?gb18030?b?u9i4tKO6IFJFOiC72Li0o7plcGljc3F0IG9uIGFy?==?gb18030?b?bSBib2FyZA==?= =?gb18030?b?SGFuc2Vu?=
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
