Dear Mark, This is further to our trials of compiling EPICS for 'VxWorks 6.9' We ran the 'make' from Visual Studio (2010) Command Prompt. I am attaching following with this mail: (1) CONFIG_SITE.Common.vxWorksCommon : This is the only file we have modified. (2) make_output.txt : output of the make process (with error message appended at the bottom ) (3) errMsg.jpg : This is a pop-up message we encountered 42 times towards the end of 'make' . We had to press 'OK' everytime to proceed. During this trial no changes were made related to the ringPointer. We would just like to add that when we are buidling EPICS base 3.14.12.4 with Visual Studio 2010 for 'Windows' as target, we are not encountering any errors. It is just that when we select 'vxWorks' as target the problems arise. Regards, Amit Chauhan RRCAT, Indore -----Original Message----- From: Mark Rivers [mailto:[email protected]] Sent: Tuesday, July 29, 2014 8:05 AM To: Amit Chauhan; 'Dirk Zimoch'; 'Eric Norum' Cc: 'Bhavna Merh' Subject: RE: EPICS on VxWorks6.9 Hi Amit, I have not heard back from you about this. As I said, many people including me are building EPICS base 3.14.12.4 with Visual Studio 2010 and are not seeing the errors you are seeing. So there must be something different about your configuration. Mark ________________________________________ From: Mark Rivers Sent: Tuesday, July 22, 2014 6:35 AM To: Amit Chauhan; 'Dirk Zimoch'; 'Eric Norum' Cc: [email protected]; 'Bhavna Merh' Subject: RE: EPICS on VxWorks6.9 Hi Amit, I think the fact that you are building for vxWorks 6.9 is not relevant. It is failing when building for the host, which is win32-x86. But you are using Visual Studio 2010, which many of us are using without any problems. Please do the following: At the top level of base type: make realclean realuninstall Then type make and send the complete output when it fails. Also please tell us what files you have modified in base/configure/os, and how you have changed them. Mark ________________________________________ From: Amit Chauhan [[email protected]] Sent: Tuesday, July 22, 2014 12:46 AM To: Mark Rivers; 'Dirk Zimoch'; 'Eric Norum' Cc: [email protected]; 'Bhavna Merh' Subject: RE: EPICS on VxWorks6.9 Hi, Thanks to Mark and Dirk for taking their time out to dwell into the problem. I am using Visual Studio 2010. As suggested, I have NOT removed volatile keyword, but I have type casted buffer as : delete [ ] (T**) buffer; As a result the make process has progressed beyond the point where it was flagging error related to ringpointer. But now the make process is stopping with following errors related to a file named 'epicsSingleton.h' : base-3-14-12-4\\include ..\\..\\..\\src\\libCom\\cxxTemplates\\epicsOnce.cpp epicsOnce.cpp ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(37) : error C2039: 'size_t' : is not a member of 'std' ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(82) : error C2955: 'epicsSingleton' : use of class template requires template argument list ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(78) : see declaration of 'epicsSingleton' ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(87) : error C2244: 'epicsSingleton<TYPE>::reference::reference::reference' : unable to resolve function overload ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(89) : error C2954: template definitions cannot nest ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(57) : error C2027: use of undefined type 'epicsSingleton<class epicsMutex>' ..\..\..\src\libCom\cxxTemplates\epicsOnce.cpp(40) : see reference to class template instantiation 'epicsSingleton<class epicsMutex>' being compiled ..\..\..\src\libCom\cxxTemplates\epicsSingleton.h(57) : error C2027: use of undefined type 'epicsSingleton<class tsFreeList<class epicsOnceImpl,16,class epicsMutex> >' ..\..\..\src\libCom\cxxTemplates\epicsOnce.cpp(48) : see reference to class template instantiation 'epicsSingleton<class tsFreeList<class epicsOnceImpl,16,class epicsMutex> >' being compiled make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86' make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom' make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src' I am relatively new to EPICS and for the first time trying to build it for VxWorks. Suggestions to resolve these issues will be of help. Regards, Amit Chauhan RRCAT, Indore -----Original Message----- From: Mark Rivers [mailto:[email protected]] Sent: Monday, July 21, 2014 5:56 PM To: Dirk Zimoch; Eric Norum; [email protected] Cc: [email protected] Subject: RE: EPICS on VxWorks6.9 > I just see that this is not a problem with vxWorks 6.9 but with the > Windows host build. > Eric, have you tested your change with Windows? That change was done in EPICS base 3.14.10 in 2008. We have certainly built a lot on Windows since then! The question is what version of Visual Studio is Amit using? He did not tell us that in the original post. I have used Visual Studio 2008 and 2010 to compile base since 2008 and have not had this problem. I suspect that Amit is using a more recent version of Visual Studio? Mark ________________________________________ From: Dirk Zimoch [[email protected]] Sent: Monday, July 21, 2014 3:15 AM To: Mark Rivers; Eric Norum Cc: [email protected] Subject: Re: EPICS on VxWorks6.9 On 16.07.2014 20:40, Mark Rivers wrote: >> The problem is >> T * volatile * buffer; >> in epicsRingPointer.h. >> I am not sure if "volatile" really makes any sense here.I strongly suggest NOT removing the volatile keyword. > > > In October 2008 we struggled with a very nasty bug in epicsRingPointer.h. The symptoms were: > > - Only failed on multi-processor systems > - Only failed with recent versions of gcc with optimization enabled > - Only failed 1 in 100,000 times > > Eric Norum fixed the problem. The changes included the following (comparison of epicsRingPointer.h from base 3.14.8.2 and 3.14.12.4) > > > -private: // Data > - int nextPush; > - int nextPop; > +private: /* Data */ > + volatile int nextPush; > + volatile int nextPop; > int size; > - T **buffer; > + T * volatile * buffer; > }; > > So he added that volatile keyword, and it would need a lot of testing to prove it is not needed. > > Mark In that case the volatile needs to be removed for the delete, because it seems that the compiler thinks that there is no delete operator for arrays of volatiles and implicitly converting volatile away is considered impossible. I just see that this is not a problem with vxWorks 6.9 but with the Windows host build. Eric, have you tested your change with Windows? > > > -----Original Message----- > From: [email protected] [mailto:[email protected]] On Behalf Of Dirk Zimoch > Sent: Wednesday, July 16, 2014 7:00 AM > To: [email protected] > Subject: Re: EPICS on VxWorks6.9 > > Newer C++ compilers consider more and more things in EPICS errors. And > maybe they are right. > > The problem is > T * volatile * buffer; > in epicsRingPointer.h. > > I am not sure if "volatile" really makes any sense here. > > The other possibility is to cast away the "void" in the destructor. > > delete [ ] (T*) buffer; > > Or whatever the nicer C++ syntax is (probably using const_cast<T*>()?) > > Dirk > > On 16.07.2014 08:14, Amit Chauhan wrote: >> Hi, >> >> We are trying to put EPICS on VxWorks. >> >> Various information related to our setup are: >> >> EPICS base version : 3.14.12.4 >> >> VxWorks Version : 6.9 >> >> Workbench version : 3.3 >> >> Host Architecture : win32 on x86 >> >> Target Architecture: ppc-32 >> >> Target Board : MVME-5500 with PowerPC 7447 processor >> >> On running the 'make' command, the EPICS build stops after a while with >> an error. >> >> *_Following is the output of the make command:_* >> >> make -C ./configure install >> >> make[1]: Entering directory `C:/EPICS/base-3-14-12-4/configure' >> >> perl ../src/tools/makeMakefile.pl O.win32-x86 ../.. >> >> perl ../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../.. >> >> perl -MExtUtils::Command -e mkpath O.Common >> >> make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install >> >> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86' >> >> make[2]: Nothing to be done for `install'. >> >> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86' >> >> make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. T_A=vxWorks-ppc32 install >> >> make[2]: Entering directory >> `C:/EPICS/base-3-14-12-4/configure/O.vxWorks-ppc32' >> >> make[2]: Nothing to be done for `install'. >> >> make[2]: Leaving directory >> `C:/EPICS/base-3-14-12-4/configure/O.vxWorks-ppc32' >> >> make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/configure' >> >> make -C ./src install >> >> make[1]: Entering directory `C:/EPICS/base-3-14-12-4/src' >> >> make -C ./tools install >> >> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools' >> >> perl ../../src/tools/makeMakefile.pl O.win32-x86 ../../.. >> >> perl ../../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../../.. >> >> perl -MExtUtils::Command -e mkpath O.Common >> >> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install >> >> make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86' >> >> make[3]: Nothing to be done for `install'. >> >> make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86' >> >> make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32 >> install >> >> make[3]: Entering directory >> `C:/EPICS/base-3-14-12-4/src/tools/O.vxWorks-ppc32' >> >> make[3]: Nothing to be done for `install'. >> >> make[3]: Leaving directory >> `C:/EPICS/base-3-14-12-4/src/tools/O.vxWorks-ppc32' >> >> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools' >> >> make -C ./makeBaseApp install >> >> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp' >> >> perl C:\EPICS\base-3-14-12-4/bin/win32-x86/makeMakefile.pl O.win32-x86 >> ../../.. >> >> perl C:\EPICS\base-3-14-12-4/bin/win32-x86/makeMakefile.pl >> O.vxWorks-ppc32 ../../.. >> >> perl -MExtUtils::Command -e mkpath O.Common >> >> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install >> >> make[3]: Entering directory >> `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.win32-x86' >> >> make[3]: Nothing to be done for `install'. >> >> make[3]: Leaving directory >> `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.win32-x86' >> >> make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32 >> install >> >> make[3]: Entering directory >> `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.vxWorks-ppc32' >> >> make[3]: Nothing to be done for `install'. >> >> make[3]: Leaving directory >> `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.vxWorks-ppc32' >> >> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp' >> >> make -C ./makeBaseExt install >> >> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt' >> >> perl C:\EPICS\base-3-14-12-4/bin/win32-x86/makeMakefile.pl O.win32-x86 >> ../../.. >> >> perl C:\EPICS\base-3-14-12-4/bin/win32-x86/makeMakefile.pl >> O.vxWorks-ppc32 ../../.. >> >> perl -MExtUtils::Command -e mkpath O.Common >> >> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install >> >> make[3]: Entering directory >> `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.win32-x86' >> >> make[3]: Nothing to be done for `install'. >> >> make[3]: Leaving directory >> `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.win32-x86' >> >> make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32 >> install >> >> make[3]: Entering directory >> `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.vxWorks-ppc32' >> >> make[3]: Nothing to be done for `install'. >> >> make[3]: Leaving directory >> `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.vxWorks-ppc32' >> >> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt' >> >> make -C ./libCom install >> >> make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom' >> >> perl C:\EPICS\base-3-14-12-4/bin/win32-x86/makeMakefile.pl O.win32-x86 >> ../../.. >> >> perl C:\EPICS\base-3-14-12-4/bin/win32-x86/makeMakefile.pl >> O.vxWorks-ppc32 ../../.. >> >> perl -MExtUtils::Command -e mkpath O.Common >> >> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install >> >> make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86' >> >> perl ../../../src/libCom/misc/makeEpicsVersion.pl >> ../../../configure/CONFIG_BASE_VERSION ../O.Common >> >> Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION >> >> Found EPICS Version 3.14.12.4 >> >> "Installing generated generic include file >> C:\EPICS\base-3-14-12-4/include/epicsVersion.h" >> >> rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 >> -I../../../src/libCom/osi/os/default -I.. >> -I../../../src/libCom/bucketLib -I../../../src/libCom/ring >> -I../../../src/libCom/calc -I../../../src/libCom/cvtFast >> -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates >> -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib >> -I../../../src/libCom/env -I../../../src/libCom/error >> -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList >> -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh >> -I../../../src/libCom/logClient -I../../../src/libCom/macLib >> -I../../../src/libCom/misc -I../../../src/libCom/osi >> -I../../../src/libCom/taskwd -I../../../src/libCom/timer >> -I../../../src/libCom/tsDefs -IC:\EPICS\base-3-14-12-4/include/os/WIN32 >> -IC:\EPICS\base-3-14-12-4/include -fo Com.res ../Com.rc >> >> cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE >> /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT >> -DEPICS_DLL_NO -I. -I..\\O.Common -I. >> -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 >> -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. >> -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring >> -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast >> -I..\\..\\..\\src\\libCom\\cppStd >> -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf >> -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env >> -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr >> -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash >> -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient >> -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc >> -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd >> -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs >> -IC:\EPICS\base-3-14-12-4\\include\\os\\WIN32 >> -IC:\EPICS\base-3-14-12-4\\include >> ..\\..\\..\\src\\libCom\\bucketLib\\bucketLib.c >> >> bucketLib.c >> >> cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE >> /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT >> -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. >> -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 >> -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. >> -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring >> -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast >> -I..\\..\\..\\src\\libCom\\cppStd >> -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf >> -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env >> -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr >> -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash >> -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient >> -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc >> -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd >> -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs >> -IC:\EPICS\base-3-14-12-4\\include\\os\\WIN32 >> -IC:\EPICS\base-3-14-12-4\\include >> ..\\..\\..\\src\\libCom\\ring\\epicsRingPointer.cpp >> >> epicsRingPointer.cpp >> >> ..\..\..\src\libCom\ring\epicsRingPointer.h(93) : *error C2664: 'delete' >> : cannot convert parameter 1 from 'void *volatile * ' to 'void *'* >> >> * Conversion loses qualifiers* >> >> ..\..\..\src\libCom\ring\epicsRingPointer.cpp(82) : while compiling >> class-template member function '__thiscall >> epicsRingPointer<void>::~epicsRingPointer<void>(void)' >> >> make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86' >> >> make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom' >> >> make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src' >> >> */The following code is written in epicsRingPointer.h (line 93):/* >> >> inline epicsRingPointer<T>:: ~epicsRingPointer( ) >> >> { delete [ ] buffer; } >> >> If anyone can suggest us the solution to overcome this error it will be >> of help to us. >> >> Regards, >> >> Amit Chauhan, >> >> RRCAT, Indore >> > > > = = Attachment:
CONFIG_SITE.Common.vxWorksCommon Attachment:
errMsg.JPG make -C ./configure install make[1]: Entering directory `C:/EPICS/base-3-14-12-4/configure' perl ../src/tools/makeMakefile.pl O.win32-x86 ../.. perl ../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install make[2]: Entering directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86' make[2]: Nothing to be done for `install'. make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86' make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. T_A=vxWorks-ppc32 install make[2]: Entering directory `C:/EPICS/base-3-14-12-4/configure/O.vxWorks-ppc32' make[2]: Nothing to be done for `install'. make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/configure/O.vxWorks-ppc32' make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/configure' make -C ./src install make[1]: Entering directory `C:/EPICS/base-3-14-12-4/src' make -C ./tools install make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools' perl ../../src/tools/makeMakefile.pl O.win32-x86 ../../.. perl ../../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86' "Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm" mkdir ../../../lib mkdir ../../../lib/perl mkdir ../../../lib/perl/EPICS "Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm" "Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm" "Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm" "Installing script ../../../bin/win32-x86/convertRelease.pl" mkdir ../../../bin mkdir ../../../bin/win32-x86 "Installing script ../../../bin/win32-x86/cvsclean.pl" "Installing script ../../../bin/win32-x86/dos2unix.pl" "Installing script ../../../bin/win32-x86/expandVars.pl" "Installing script ../../../bin/win32-x86/filterWarnings.pl" "Installing script ../../../bin/win32-x86/fullPathName.pl" "Installing script ../../../bin/win32-x86/installEpics.pl" "Installing script ../../../bin/win32-x86/makeIncludeDbd.pl" "Installing script ../../../bin/win32-x86/makeMakefile.pl" "Installing script ../../../bin/win32-x86/makeTestfile.pl" "Installing script ../../../bin/win32-x86/mkmf.pl" "Installing script ../../../bin/win32-x86/munch.pl" "Installing script ../../../bin/win32-x86/replaceVAR.pl" "Installing script ../../../bin/win32-x86/useManifestTool.pl" make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86' make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32 install make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools/O.vxWorks-ppc32' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools/O.vxWorks-ppc32' make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools' make -C ./makeBaseApp install make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp' perl ../../bin/win32-x86/makeMakefile.pl O.win32-x86 ../../.. perl ../../bin/win32-x86/makeMakefile.pl O.vxWorks-ppc32 ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.win32-x86' "Installing script ../../../bin/win32-x86/makeBaseApp.pl" "Installing ../../../templates/makeBaseApp/top/Makefile" mkdir ../../../templates mkdir ../../../templates/makeBaseApp mkdir ../../../templates/makeBaseApp/top "Installing ../../../templates/makeBaseApp/top/configure/CONFIG" mkdir ../../../templates/makeBaseApp/top/configure "Installing ../../../templates/makeBaseApp/top/configure/CONFIG_SITE" "Installing ../../../templates/makeBaseApp/top/configure/Makefile" "Installing ../../../templates/makeBaseApp/top/configure/RELEASE" "Installing ../../../templates/makeBaseApp/top/configure/RULES" "Installing ../../../templates/makeBaseApp/top/configure/RULES.ioc" "Installing ../../../templates/makeBaseApp/top/configure/RULES_DIRS" "Installing ../../../templates/makeBaseApp/top/configure/RULES_TOP" "Installing ../../../templates/makeBaseApp/top/supportApp/Makefile" mkdir ../../../templates/makeBaseApp/top/supportApp "Installing ../../../templates/makeBaseApp/top/supportApp/Db/Makefile" mkdir ../../../templates/makeBaseApp/top/supportApp/Db "Installing ../../../templates/makeBaseApp/top/supportApp/src/Makefile" mkdir ../../../templates/makeBaseApp/top/supportApp/src "Installing ../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd" "Installing ../../../templates/makeBaseApp/top/iocApp/Makefile" mkdir ../../../templates/makeBaseApp/top/iocApp "Installing ../../../templates/makeBaseApp/top/iocApp/Db/Makefile" mkdir ../../../templates/makeBaseApp/top/iocApp/Db "Installing ../../../templates/makeBaseApp/top/iocApp/src/Makefile" mkdir ../../../templates/makeBaseApp/top/iocApp/src "Installing ../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp" "Installing ../../../templates/makeBaseApp/top/exampleApp/Makefile" mkdir ../../../templates/makeBaseApp/top/exampleApp "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/Makefile" mkdir ../../../templates/makeBaseApp/top/exampleApp/Db "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db" "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db" "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db" "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions" "Installing ../../../templates/makeBaseApp/top/exampleApp/Db/userHost.substitutions" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/Makefile" mkdir ../../../templates/makeBaseApp/top/exampleApp/src "Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c" "Installing ../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd" "Installing ../../../templates/makeBaseApp/top/exampleBoot/Makefile" mkdir ../../../templates/makeBaseApp/top/exampleBoot "Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks" "Installing ../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common" mkdir ../../../templates/makeBaseApp/top/exampleBoot/ioc "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common" "Installing ../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks" "Installing ../../../templates/makeBaseApp/top/caClientApp/Makefile" mkdir ../../../templates/makeBaseApp/top/caClientApp "Installing ../../../templates/makeBaseApp/top/caClientApp/caExample.c" "Installing ../../../templates/makeBaseApp/top/caClientApp/caMonitor.c" "Installing ../../../templates/makeBaseApp/top/caServerApp/Makefile" mkdir ../../../templates/makeBaseApp/top/caServerApp "Installing ../../../templates/makeBaseApp/top/caServerApp/README" "Installing ../../../templates/makeBaseApp/top/caServerApp/exAsyncPV.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/exChannel.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/exPV.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/exScalarPV.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/exServer.h" "Installing ../../../templates/makeBaseApp/top/caServerApp/exVectorPV.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/main.cc" "Installing ../../../templates/makeBaseApp/top/caServerApp/test.adl" "Installing ../../../templates/makeBaseApp/top/caServerApp/vxEntry.cc" "Installing ../../../templates/makeBaseApp/top/iocBoot/Makefile" mkdir ../../../templates/makeBaseApp/top/iocBoot "Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks" "Installing ../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common" mkdir ../../../templates/makeBaseApp/top/iocBoot/ioc "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks" "Installing ../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS" make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.win32-x86' make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32 install make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.vxWorks-ppc32' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.vxWorks-ppc32' make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp' make -C ./makeBaseExt install make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt' perl ../../bin/win32-x86/makeMakefile.pl O.win32-x86 ../../.. perl ../../bin/win32-x86/makeMakefile.pl O.vxWorks-ppc32 ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.win32-x86' "Installing script ../../../bin/win32-x86/makeBaseExt.pl" "Installing ../../../templates/makeBaseExt/top/Makefile" mkdir ../../../templates/makeBaseExt mkdir ../../../templates/makeBaseExt/top "Installing ../../../templates/makeBaseExt/top/README" "Installing ../../../templates/makeBaseExt/top/configure/CONFIG" mkdir ../../../templates/makeBaseExt/top/configure "Installing ../../../templates/makeBaseExt/top/configure/CONFIG_SITE" "Installing ../../../templates/makeBaseExt/top/configure/Makefile" "Installing ../../../templates/makeBaseExt/top/configure/RELEASE" "Installing ../../../templates/makeBaseExt/top/configure/RULES" "Installing ../../../templates/makeBaseExt/top/configure/RULES_DIRS" "Installing ../../../templates/makeBaseExt/top/configure/RULES_TOP" "Installing ../../../templates/makeBaseExt/top/configure/RULES_PYTHON" "Installing ../../../templates/makeBaseExt/top/configure/RULES_IDL" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.linux-x86.linux-386" mkdir ../../../templates/makeBaseExt/top/configure/os "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG.win32-x86-borland.win32-x86-borland" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.Common.Common" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc-gnu.hpux-parisc-gnu" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.hpux-parisc.hpux-parisc" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.interix-x86.interix-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-borland.linux-x86-borland" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-borland.win32-x86-borland" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86" "Installing ../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64" "Installing ../../../templates/makeBaseExt/top/src/Makefile" mkdir ../../../templates/makeBaseExt/top/src "Installing ../../../templates/makeBaseExt/top/exampleExt/Makefile" mkdir ../../../templates/makeBaseExt/top/exampleExt "Installing ../../../templates/makeBaseExt/top/exampleExt/caExample.c" "Installing ../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM" "Installing ../../../templates/makeBaseExt/top/simpleExt/Makefile" mkdir ../../../templates/makeBaseExt/top/simpleExt make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.win32-x86' make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32 install make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.vxWorks-ppc32' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.vxWorks-ppc32' make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt' make -C ./libCom install make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom' perl ../../bin/win32-x86/makeMakefile.pl O.win32-x86 ../../.. perl ../../bin/win32-x86/makeMakefile.pl O.vxWorks-ppc32 ../../.. perl -MExtUtils::Command -e mkpath O.Common make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86' perl ../../../src/libCom/misc/makeEpicsVersion.pl ../../../configure/CONFIG_BASE_VERSION ../O.Common Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION Found EPICS Version 3.14.12.4 "Installing generated generic include file ../../../include/epicsVersion.h" mkdir ../../../include "Installing generic include file ../../../include/bucketLib.h" "Installing generic include file ../../../include/epicsRingPointer.h" "Installing generic include file ../../../include/epicsRingBytes.h" "Installing generic include file ../../../include/postfix.h" "Installing generic include file ../../../include/cvtFast.h" "Installing generic include file ../../../include/epicsAlgorithm.h" "Installing generic include file ../../../include/epicsExcept.h" "Installing generic include file ../../../include/epicsMemory.h" "Installing generic include file ../../../include/resourceLib.h" "Installing generic include file ../../../include/tsDLList.h" "Installing generic include file ../../../include/tsSLList.h" "Installing generic include file ../../../include/tsMinMax.h" "Installing generic include file ../../../include/tsBTree.h" "Installing generic include file ../../../include/tsFreeList.h" "Installing generic include file ../../../include/epicsSingleton.h" "Installing generic include file ../../../include/epicsGuard.h" "Installing generic include file ../../../include/epicsOnce.h" "Installing generic include file ../../../include/dbmf.h" "Installing generic include file ../../../include/ellLib.h" "Installing generic include file ../../../include/envDefs.h" "Installing generic include file ../../../include/epicsPrint.h" "Installing generic include file ../../../include/errMdef.h" "Installing generic include file ../../../include/errSymTbl.h" "Installing generic include file ../../../include/errlog.h" "Installing generic include file ../../../include/error.h" "Installing generic include file ../../../include/fdManager.h" "Installing generic include file ../../../include/fdmgr.h" "Installing generic include file ../../../include/freeList.h" "Installing generic include file ../../../include/gpHash.h" "Installing generic include file ../../../include/iocsh.h" "Installing generic include file ../../../include/registry.h" "Installing generic include file ../../../include/libComRegister.h" "Installing generic include file ../../../include/iocLog.h" "Installing generic include file ../../../include/logClient.h" "Installing generic include file ../../../include/macLib.h" "Installing generic include file ../../../include/adjustment.h" "Installing generic include file ../../../include/cantProceed.h" "Installing generic include file ../../../include/dbDefs.h" "Installing generic include file ../../../include/epicsConvert.h" "Installing generic include file ../../../include/epicsExit.h" "Installing generic include file ../../../include/epicsStdlib.h" "Installing generic include file ../../../include/epicsString.h" "Installing generic include file ../../../include/epicsTypes.h" "Installing generic include file ../../../include/shareLib.h" "Installing generic include file ../../../include/epicsExport.h" "Installing generic include file ../../../include/unixFileName.h" "Installing generic include file ../../../include/locationException.h" "Installing generic include file ../../../include/ipAddrToAsciiAsynchronous.h" "Installing generic include file ../../../include/compilerDependencies.h" "Installing generic include file ../../../include/epicsUnitTest.h" "Installing generic include file ../../../include/testMain.h" "Installing generic include file ../../../include/os/WIN32/osiFileName.h" mkdir ../../../include/os mkdir ../../../include/os/WIN32 "Installing generic include file ../../../include/osiSock.h" "Installing generic include file ../../../include/os/WIN32/osdSock.h" "Installing generic include file ../../../include/epicsInterrupt.h" "Installing os dependent include file ../../../include/os/WIN32/osdInterrupt.h" "Installing generic include file ../../../include/epicsMutex.h" "Installing generic include file ../../../include/os/WIN32/osdMutex.h" "Installing generic include file ../../../include/epicsEvent.h" "Installing generic include file ../../../include/os/WIN32/osdEvent.h" "Installing generic include file ../../../include/os/WIN32/epicsMath.h" "Installing os dependent include file ../../../include/os/WIN32/osdMessageQueue.h" "Installing generic include file ../../../include/os/WIN32/osdStrtod.h" "Installing generic include file ../../../include/epicsAssert.h" "Installing generic include file ../../../include/epicsFindSymbol.h" "Installing generic include file ../../../include/osiPoolStatus.h" "Installing generic include file ../../../include/os/WIN32/osdPoolStatus.h" "Installing generic include file ../../../include/os/WIN32/osdThread.h" "Installing generic include file ../../../include/epicsThread.h" "Installing generic include file ../../../include/epicsTime.h" "Installing generic include file ../../../include/epicsGeneralTime.h" "Installing generic include file ../../../include/os/WIN32/osdTime.h" "Installing generic include file ../../../include/generalTimeSup.h" "Installing generic include file ../../../include/osiClockTime.h" "Installing generic include file ../../../include/epicsSignal.h" "Installing generic include file ../../../include/osiProcess.h" "Installing generic include file ../../../include/os/WIN32/osiUnistd.h" "Installing generic include file ../../../include/osiWireFormat.h" "Installing os dependent include file ../../../include/os/WIN32/osdWireFormat.h" "Installing generic include file ../../../include/os/WIN32/osdWireConfig.h" "Installing generic include file ../../../include/epicsEndian.h" "Installing os dependent include file ../../../include/os/WIN32/epicsReadline.h" "Installing generic include file ../../../include/epicsMessageQueue.h" "Installing generic include file ../../../include/epicsStdio.h" "Installing generic include file ../../../include/epicsStdioRedirect.h" "Installing generic include file ../../../include/os/WIN32/epicsGetopt.h" "Installing generic include file ../../../include/devLib.h" "Installing generic include file ../../../include/devLibVME.h" "Installing generic include file ../../../include/devLibVMEImpl.h" "Installing os dependent include file ../../../include/os/WIN32/osdVME.h" "Installing generic include file ../../../include/taskwd.h" "Installing generic include file ../../../include/epicsTimer.h" "Installing generic include file ../../../include/tsDefs.h" rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32 -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/WIN32 -I../../../include -fo Com.res ../Com.rc Microsoft (R) Windows (R) Resource Compiler Version 6.1.7600.16385Copyright (C) Microsoft Corporation. All rights reserved. cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\bucketLib\\bucketLib.c bucketLib.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\ring\\epicsRingPointer.cpp epicsRingPointer.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\ring\\epicsRingBytes.c epicsRingBytes.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\calc\\postfix.c postfix.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\calc\\calcPerform.c calcPerform.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\cvtFast\\cvtFast.c cvtFast.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\cxxTemplates\\resourceLib.cpp resourceLib.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\cxxTemplates\\epicsOnce.cpp epicsOnce.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\cxxTemplates\\epicsSingletonMutex.cpp epicsSingletonMutex.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\dbmf\\dbmf.c dbmf.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\ellLib\\ellLib.c ellLib.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\env\\envSubr.c envSubr.c perl ../../../src/libCom/env/bldEnvData.pl ../../../configure Generating envData.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include envData.c envData.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\error\\errlog.c errlog.c ..\..\..\src\libCom\error\errlog.c(97) : warning C4018: '>=' : signed/unsigned mismatch cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\error\\errSymLib.c errSymLib.c perl ../../../src/libCom/error/makeStatTbl.pl ../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h ../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h ../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h ../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include errSymTbl.c errSymTbl.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\fdmgr\\fdmgr.cpp fdmgr.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\fdmgr\\fdManager.cpp fdManager.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\freeList\\freeListLib.c freeListLib.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\gpHash\\gpHashLib.c gpHashLib.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\iocsh\\iocsh.cpp iocsh.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\iocsh\\registry.c registry.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\iocsh\\libComRegister.c libComRegister.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\logClient\\iocLog.c iocLog.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\logClient\\logClient.c logClient.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\macLib\\macCore.c macCore.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\macLib\\macEnv.c macEnv.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\macLib\\macUtil.c macUtil.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\misc\\aToIPAddr.c aToIPAddr.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\misc\\adjustment.c adjustment.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\misc\\cantProceed.c cantProceed.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\misc\\epicsConvert.c epicsConvert.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\misc\\epicsExit.c epicsExit.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\misc\\epicsStdlib.c epicsStdlib.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\misc\\epicsString.c epicsString.c ..\..\..\src\libCom\misc\epicsString.c(46) : warning C4018: '<' : signed/unsigned mismatch ..\..\..\src\libCom\misc\epicsString.c(46) : warning C4018: '<' : signed/unsigned mismatch ..\..\..\src\libCom\misc\epicsString.c(49) : warning C4018: '>=' : signed/unsigned mismatch ..\..\..\src\libCom\misc\epicsString.c(138) : warning C4018: '<' : signed/unsigned mismatch cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\misc\\truncateFile.c truncateFile.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\misc\\ipAddrToAsciiAsynchronous.cpp ipAddrToAsciiAsynchronous.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\misc\\epicsUnitTest.c epicsUnitTest.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\epicsThread.cpp epicsThread.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\epicsMutex.cpp epicsMutex.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\epicsEvent.cpp epicsEvent.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\epicsTime.cpp epicsTime.cpp ..\..\..\src\libCom\osi\epicsTime.cpp(340) : warning C4244: '=' : conversion from 'time_t' to 'long', possible loss of data cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\epicsMessageQueue.cpp epicsMessageQueue.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\epicsMath.cpp epicsMath.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\epicsGeneralTime.c epicsGeneralTime.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\osiClockTime.c osiClockTime.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdSock.c osdSock.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdSockAddrReuse.cpp osdSockAddrReuse.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\osiSock.c osiSock.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\systemCallIntMech.cpp systemCallIntMech.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\epicsSocketConvertErrnoToString.cpp epicsSocketConvertErrnoToString.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\default\\osdAssert.c osdAssert.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdFindSymbol.c osdFindSymbol.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\default\\osdInterrupt.c osdInterrupt.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdPoolStatus.c osdPoolStatus.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdSignal.cpp osdSignal.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\default\\osdEnv.c osdEnv.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_EPICS /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\default\\epicsReadline.c epicsReadline.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\epicsTempFile.cpp epicsTempFile.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\epicsStdio.c epicsStdio.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdStdio.c osdStdio.c cl -c -DDONT_USE_POSIX_THREAD_PRIORITY_SCHEDULING /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdThread.c osdThread.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdMutex.c osdMutex.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdEvent.c osdEvent.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdTime.cpp osdTime.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdProcess.c osdProcess.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\osdNetIntf.c osdNetIntf.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\default\\osdMessageQueue.cpp osdMessageQueue.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\devLibVME.c devLibVME.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\default\\devLibVMEOSD.c devLibVMEOSD.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\taskwd\\taskwd.c taskwd.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\timer\\epicsTimer.cpp epicsTimer.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\timer\\timer.cpp timer.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\timer\\timerQueue.cpp timerQueue.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\timer\\timerQueueActive.cpp timerQueueActive.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\timer\\timerQueueActiveMgr.cpp timerQueueActiveMgr.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\timer\\timerQueuePassive.cpp timerQueuePassive.cpp cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\tsDefs\\tsDefs.c tsDefs.c cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\epicsGetopt.c epicsGetopt.c cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\setThreadName.cpp setThreadName.cpp cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE /D_CRT_NONSTDC_NO_DEPRECATE /Ox /GL /W3 /w44355 /MT -DEPICS_DLL_NO /TP -I. -I..\\O.Common -I. -I..\\..\\..\\src\\libCom\\osi\\os\\WIN32 -I..\\..\\..\\src\\libCom\\osi\\os\\default -I.. -I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring -I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast -I..\\..\\..\\src\\libCom\\cppStd -I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf -I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env -I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr -I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash -I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient -I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc -I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd -I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs -I..\\..\\..\\include\\os\\WIN32 -I..\\..\\..\\include ..\\..\\..\\src\\libCom\\osi\\os\\WIN32\\forceBadAllocException.cpp forceBadAllocException.cpp lib /nologo /verbose /out:Com.lib /LTCG bucketLib.obj epicsRingPointer.obj epicsRingBytes.obj postfix.obj calcPerform.obj cvtFast.obj resourceLib.obj epicsOnce.obj epicsSingletonMutex.obj dbmf.obj ellLib.obj envSubr.obj envData.obj errlog.obj errSymLib.obj errSymTbl.obj fdmgr.obj fdManager.obj freeListLib.obj gpHashLib.obj iocsh.obj registry.obj libComRegister.obj iocLog.obj logClient.obj macCore.obj macEnv.obj macUtil.obj aToIPAddr.obj adjustment.obj cantProceed.obj epicsConvert.obj epicsExit.obj epicsStdlib.obj epicsString.obj truncateFile.obj ipAddrToAsciiAsynchronous.obj epicsUnitTest.obj epicsThread.obj epicsMutex.obj epicsEvent.obj epicsTime.obj epicsMessageQueue.obj epicsMath.obj epicsGeneralTime.obj osiClockTime.obj osdSock.obj osdSockAddrReuse.obj osiSock.obj systemCallIntMech.obj epicsSocketConvertErrnoToString.obj osdAssert.obj osdFindSymbol.obj osdInterrupt.obj osdPoolStatus.obj osdSignal.obj osdEnv.obj epicsReadline.obj epicsTempFile.obj epicsStdio.obj osdStdio.obj osdThread.obj osdMutex.obj osdEvent.obj osdTime.obj osdProcess.obj osdNetIntf.obj osdMessageQueue.obj devLibVME.obj devLibVMEOSD.obj taskwd.obj epicsTimer.obj timer.obj timerQueue.obj timerQueueActive.obj timerQueueActiveMgr.obj timerQueuePassive.obj tsDefs.obj epicsGetopt.obj setThreadName.obj forceBadAllocException.obj Appending forceBadAllocException.obj Appending setThreadName.obj Appending epicsGetopt.obj Appending tsDefs.obj Appending timerQueuePassive.obj Appending timerQueueActiveMgr.obj Appending timerQueueActive.obj Appending timerQueue.obj Appending timer.obj Appending epicsTimer.obj Appending taskwd.obj Appending devLibVMEOSD.obj Appending devLibVME.obj Appending osdMessageQueue.obj Appending osdNetIntf.obj Appending osdProcess.obj Appending osdTime.obj Appending osdEvent.obj Appending osdMutex.obj Appending osdThread.obj Appending osdStdio.obj Appending epicsStdio.obj Appending epicsTempFile.obj Appending epicsReadline.obj Appending osdEnv.obj Appending osdSignal.obj Appending osdPoolStatus.obj Appending osdInterrupt.obj Appending osdFindSymbol.obj Appending osdAssert.obj Appending epicsSocketConvertErrnoToString.obj Appending systemCallIntMech.obj Appending osiSock.obj Appending osdSockAddrReuse.obj Appending osdSock.obj Appending osiClockTime.obj Appending epicsGeneralTime.obj Appending epicsMath.obj Appending epicsMessageQueue.obj Appending epicsTime.obj Appending epicsEvent.obj Appending epicsMutex.obj Appending epicsThread.obj Appending epicsUnitTest.obj Appending ipAddrToAsciiAsynchronous.obj Appending truncateFile.obj Appending epicsString.obj Appending epicsStdlib.obj Appending epicsExit.obj Appending epicsConvert.obj Appending cantProceed.obj Appending adjustment.obj Appending aToIPAddr.obj Appending macUtil.obj Appending macEnv.obj Appending macCore.obj Appending logClient.obj Appending iocLog.obj Appending libComRegister.obj Appending registry.obj Appending iocsh.obj Appending gpHashLib.obj Appending freeListLib.obj Appending fdManager.obj Appending fdmgr.obj Appending errSymTbl.obj Appending errSymLib.obj Appending errlog.obj Appending envData.obj Appending envSubr.obj Appending ellLib.obj Appending dbmf.obj Appending epicsSingletonMutex.obj Appending epicsOnce.obj Appending resourceLib.obj Appending cvtFast.obj Appending calcPerform.obj Appending postfix.obj Appending epicsRingBytes.obj Appending epicsRingPointer.obj Appending bucketLib.obj "Installing library ../../../lib/win32-x86/Com.lib" mkdir ../../../lib/win32-x86 "Installing html ../../../html//freeList/freeList.html" mkdir ../../../html mkdir ../../../html/freeList "Installing html ../../../html//gpHash/gpHash.html" mkdir ../../../html/gpHash make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86' make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32 install make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom/O.vxWorks-ppc32' "Installing generic include file ../../../include/os/vxWorks/osiFileName.h" mkdir ../../../include/os/vxWorks "Installing generic include file ../../../include/os/vxWorks/osdSock.h" "Installing generic include file ../../../include/os/vxWorks/osdInterrupt.h" "Installing generic include file ../../../include/os/vxWorks/osdMutex.h" "Installing generic include file ../../../include/os/vxWorks/osdEvent.h" "Installing generic include file ../../../include/os/vxWorks/epicsMath.h" "Installing generic include file ../../../include/os/vxWorks/osdMessageQueue.h" "Installing generic include file ../../../include/os/vxWorks/osdStrtod.h" "Installing os dependent include file ../../../include/os/vxWorks/osdPoolStatus.h" "Installing generic include file ../../../include/os/vxWorks/osdThread.h" "Installing generic include file ../../../include/os/vxWorks/osdTime.h" "Installing os dependent include file ../../../include/os/vxWorks/osiUnistd.h" "Installing os dependent include file ../../../include/os/vxWorks/osdWireFormat.h" "Installing generic include file ../../../include/os/vxWorks/osdWireConfig.h" "Installing os dependent include file ../../../include/os/vxWorks/epicsReadline.h" "Installing os dependent include file ../../../include/os/vxWorks/epicsGetopt.h" "Installing generic include file ../../../include/os/vxWorks/osdVME.h" "Installing generic include file ../../../include/os/vxWorks/camacLib.h" "Installing generic include file ../../../include/os/vxWorks/epicsDynLink.h" "Installing generic include file ../../../include/os/vxWorks/module_types.h" "Installing generic include file ../../../include/os/vxWorks/task_params.h" "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/osi/os/vxWorks/vxComLibrary.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/bucketLib/bucketLib.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/ring/epicsRingPointer.cpp "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/ring/epicsRingBytes.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/calc/postfix.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/calc/calcPerform.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/cvtFast/cvtFast.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/cxxTemplates/resourceLib.cpp "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/cxxTemplates/epicsOnce.cpp "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/dbmf/dbmf.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/ellLib/ellLib.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/env/envSubr.c perl ../../../src/libCom/env/bldEnvData.pl ../../../configure Generating envData.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip envData.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/error/errlog.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/error/errSymLib.c perl ../../../src/libCom/error/makeStatTbl.pl ../../../src/libCom/osi/devLib.h ../../../src/as/asLib.h ../../../src/db/dbAccessDefs.h ../../../src/dbStatic/devSup.h ../../../src/dbStatic/drvSup.h ../../../src/dbStatic/recSup.h ../../../src/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/cas/generic/casdef.h ../../../src/gdd/gddAppFuncTable.h "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip errSymTbl.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/fdmgr/fdmgr.cpp "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/fdmgr/fdManager.cpp "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/freeList/freeListLib.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/gpHash/gpHashLib.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/iocsh/iocsh.cpp "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/iocsh/registry.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/iocsh/libComRegister.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/logClient/iocLog.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/logClient/logClient.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/macLib/macCore.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/macLib/macEnv.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/macLib/macUtil.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/aToIPAddr.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/adjustment.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/cantProceed.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/epicsConvert.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/epicsExit.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/epicsStdlib.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/epicsString.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/truncateFile.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/misc/epicsUnitTest.c "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/osi/epicsThread.cpp "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/osi/epicsMutex.cpp "" C:/WindRiver/gnu/4.3.3-vxworks-6.9/x86-win32/bin/ccppc -c -DCPU=PPC32 -DvxWorks=vxWorks -include C:/WindRiver/vxworks-6.9/target/h/vxWorks.h -O2 -Wall -mstrict-align -mlongcall -fno-builtin -MMD -I. -I../O.Common -I. -I../../../src/libCom/osi/os/vxWorks -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/logClient -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/tsDefs -I../../../include/os/vxWorks -I../../../include -IC:/WindRiver/vxworks-6.9/target/h -IC:/WindRiver/vxworks-6.9/target/h/wrn/coreip ../../../src/libCom/osi/epicsEvent.cpp make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.vxWorks-ppc32' make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom' make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src' *********** Error messages received on the command prompt *************** C:\EPICS\base-3-14-12-4>make >make_output.txt In file included from ../../../src/libCom/osi/epicsStdio.h:15, from ../../../src/libCom/osi/epicsStdioRedirect.h:19, from ../../../src/libCom/osi/epicsEvent.cpp:19: C:/WindRiver/vxworks-6.9/target/h/stdio.h:318: error: declaration of C function 'int oprintf(int (*)(...), _Vx_usr_arg_t, const char*, ...)' conflicts with C:/WindRiver/vxworks-6.9/target/h/stdio.h:206: error: previous declaration 'int oprintf(int (*)(char*, size_t, _Vx_usr_arg_t), _Vx_usr_arg_t, const char*, ...)' here C:/WindRiver/vxworks-6.9/target/h/stdio.h:337: error: declaration of C function 'int voprintf(int (*)(...), _Vx_usr_arg_t, const char*, __va_list_tag*)' conflic ts with C:/WindRiver/vxworks-6.9/target/h/stdio.h:225: error: previous declaration 'int voprintf(int (*)(char*, size_t, _Vx_usr_arg_t), _Vx_usr_arg_t, const char*, __va _list_tag*)' here C:/WindRiver/vxworks-6.9/target/h/stdio.h: In function 'int voprintf(int (*)(... ), _Vx_usr_arg_t, const char*, __va_list_tag*)': C:/WindRiver/vxworks-6.9/target/h/stdio.h:348: error: invalid conversion from 'i nt (*)(char*, size_t, _Vx_usr_arg_t)' to 'int (*)(...)' C:/WindRiver/vxworks-6.9/target/h/stdio.h:348: error: initializing argument 1 of 'int voprintf(int (*)(...), _Vx_usr_arg_t, const char*, __va_list_tag*)' make[3]: *** [epicsEvent.o] Error 1 make[2]: *** [install.vxWorks-ppc32] Error 2 make[1]: *** [libCom.install] Error 2 make: *** [src.install] Error 2 C:\EPICS\base-3-14-12-4>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
