1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Subroutine invoked only when PV limit exceeded?
To: "Poff, Mark A" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Jul 2014 13:26:27 -0500
Hi Mark,
On 07/28/2014 01:01 PM, Poff, Mark A wrote:
> Andrew, thanks very much for that suggestion.  I modified the sub record
> as follows and it seems to work:
> record(“MY_PV_sub”)
> field(SDIS, "MY_PV.SEVR")
> field(DISV, "0")
> field(INPA, “MY_PV”)
> field(SNAM, “MY_PV_subroutine”)
> This prevents the subroutine from being called when the Severity is zero
> - which is a significant improvement - but if the PV value bounces
> around while in the HIHI range (for example), the subroutine is called
> each time.  What I was hoping for is a setup which calls the subroutine
> only once when an alarm state is entered, and isn't called again until
> the alarm state is exited/re-entered.  For example, perhaps the
> subroutine, when called, could examine the current severity level and
> change the DISV value on the fly to a different severity level…but that
> might be a pretty ugly way to do it.  Do you have any thoughts?
You should look at the HYST field of the longin record, which was added
to prevent alarm chattering (it specifies a dead-band that the value
must exceed before the record will exit back out of the current alarm
level). Then try removing the foward link from MY_PV and make the SDIS
link in MY_PV_sub a CP link, so it will process the MY_PV_sub record
only when a monitor event occurs because the value of MY_PV.SEVR has
changed.
I think a combination of those two should get you what you want.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RE: Subroutine invoked only when PV limit exceeded? Poff, Mark A
Re: Subroutine invoked only when PV limit exceeded? Andrew Johnson
Prev: RE: Subroutine invoked only when PV limit exceeded? Poff, Mark A
Next: RE: Subroutine invoked only when PV limit exceeded? Poff, Mark A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
