1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Subroutine invoked only when PV limit exceeded?
Cc: "Poff, Mark A" <[email protected]>
Date: Mon, 28 Jul 2014 15:18:18 +0000
Hello all,
In my EPICS database, for certain PVs I use forward links and sub records such that, whenever the PV value changes, a subroutine is called.  It’s a pretty basic implementation:
record(longin, “MY_PV”)
    field(SCAN, “Passive”)
    field(HIHI, “30”)
    field(HHSV, “MAJOR”)
    field(FLNK, “MY_PV_sub”)
record(“MY_PV_sub”)
    field(INPA, “MY_PV”)
    field(SNAM, “MY_PV_subroutine”)
What I’d like to do additionally (or instead) is to call a subroutine only when MY_PV goes to the HIHI alarm state (in the example above, when the value of MY_PV goes from less than 30 to 30 or greater).  I assumed it could be done by somehow looking at MY_PV.SEVR, but I can’t figure out how to do it.  Is it possible to define the database records so that a subroutine is executed only when the associated PV goes into an alarm state?
Thanks!
-Mark
Re: Subroutine invoked only when PV limit exceeded? Andrew Johnson
Prev: RE: can't see epicsqt widgets in QT designer Andrew Rhyder
Next: Re: Subroutine invoked only when PV limit exceeded? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
