1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: StreamDevice, asynDriver or some other solution?
To: Eric Norum <[email protected]>, Rod Nussbaumer <[email protected]>
Date: Wed, 23 Jul 2014 03:04:57 +0000
Hi Rod,
In addition to what Eric said, here are a couple of more benefits of specifying the terminators in the asyn layer:
- It allows the asyn record to be used for I/O to the device for debugging and testing.  If the terminators are only defined on the protocol file then this is not possible.
- Many devices allow the terminators to be defined using the front panel, i.e. they are not fixed.  They thus are not really part of the protocol, they are a configuration parameter of the device, and as such I believe they should be set in the startup script, not in the protocol file.
From: [email protected] [[email protected]] on behalf of Eric Norum [[email protected]]
Sent: Tuesday, July 22, 2014 5:56 PM
To: Rod Nussbaumer
Cc: [email protected]
Subject: Re: StreamDevice, asynDriver or some other solution?
Specifying the terminators in the startup script rather then the protocol file is useful when an instrument has both a serial or ‘raw TCP’ interface (which require terminators) and a GPIB or USB-TMC interface (which often do not require terminators since they have another ‘end of message’ mechanism).  Omitting the terminator information from the protocol file allows the same protocol file to be used in both cases.
If the instrument in question has only an interface or interfaces needing terminators, then specifying the terminators in the protocol file is probably the best way to go.
YMMV
On Jul 22, 2014, at 3:45 PM, Rod Nussbaumer <[email protected]<mailto:[email protected]>> wrote:
Bryan:
I completely concur with Mark's assessment that StreamDevice is the optimal approach for an EPICS interface to your device.
I do have a question for Mark, however. In my use of SteamDevice, I typically do not use asynOctetSetInputEos to terminate lines in the asyn driver. Is there some tangible benefit that I am missing by using StreamDevice to specify line terminators? As a developer, it feels more natural to specify the terminator character in the protocol file, where everything else related to the data communication with a device is specified. If there is a good reason to do it int he asyn layer, I will consider doing that way in future systems.
Eric Norum
StreamDevice, asynDriver or some other solution? Bryan J. Boardman / Aware Electronics Corp.
RE: StreamDevice, asynDriver or some other solution? Mark Rivers
Re: StreamDevice, asynDriver or some other solution? Rod Nussbaumer
Re: StreamDevice, asynDriver or some other solution? Eric Norum
Prev: Re: StreamDevice, asynDriver or some other solution? Eric Norum
Next: Tabbed Container Ability Patard Charles-Henri
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: StreamDevice, asynDriver or some other solution? Dirk Zimoch
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
