Specifying the terminators in the startup script rather then the protocol file is useful when an instrument has both a serial or ‘raw TCP’ interface (which require terminators) and a GPIB or USB-TMC interface (which often do not require terminators since they have another ‘end of message’ mechanism). Omitting the terminator information from the protocol file allows the same protocol file to be used in both cases. If the instrument in question has only an interface or interfaces needing terminators, then specifying the terminators in the protocol file is probably the best way to go. YMMV Bryan:
I completely concur with Mark's assessment that StreamDevice is the optimal approach for an EPICS interface to your device.
I do have a question for Mark, however. In my use of SteamDevice, I typically do not use asynOctetSetInputEos to terminate lines in the asyn driver. Is there some tangible benefit that I am missing by using StreamDevice to specify line terminators? As a developer, it feels more natural to specify the terminator character in the protocol file, where everything else related to the data communication with a device is specified. If there is a good reason to do it int he asyn layer, I will consider doing that way in future systems.
- RE: StreamDevice, asynDriver or some other solution? Mark Rivers
- StreamDevice, asynDriver or some other solution? Bryan J. Boardman / Aware Electronics Corp.
- Re: StreamDevice, asynDriver or some other solution? Rod Nussbaumer
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
