1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: StreamDevice, asynDriver or some other solution?
To: "'Bryan J. Boardman / Aware Electronics Corp.'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 22 Jul 2014 19:45:13 +0000
Hi Bryan,
I think you are on exactly the right track in recommending StreamDevice for this application.
Here is a slightly tweaked version of what you sent:
Here is the .proto file.  Don’t need the TERMINATOR, let that be set for the port with asynOctetSetInputEos, etc.
# Get the current reading. Send BELL character (\a) and P character to get reading which is a float.
get_aware_reading {
    out "\aP"; in "%f";
A db file (aware.db) perhaps like this:
record (stringout, "$(P):get_aware_reading")
    field (DTYP, "stream")
    field (OUT,  "@aware.proto info $(PORT)")
A CMD file perhaps like this:
dbLoadDatabase "$(TOP)/dbd/streamApp.dbd"
streamApp_registerRecordDeviceDriver
#where can protocols be located?
epicsEnvSet "STREAM_PROTOCOL_PATH", ".:protocols:../protocols/"
#setup the Moxa terminal server
drvAsynIPPortConfigure "serial1", "164.54.160.22 2101"
asynOctetSetOutputEos(”serial1”,0, “\r\n”)
asynOctetSetInputEos(“serial1”,0, “\r\n”)
drvAsynSerialPortConfigure(“serial2”, “/dev/ttys0”)
asynSetOption(“serial2”,0,”baud”,”9600”)
asynSetOption(“serial2”,0,”bits”,”8”)
asynSetOption(“serial2”,0,”stop”,”1”)
asynOctetSetOutputEos(”serial2”,0, “\r\n”)
asynOctetSetInputEos(“serial2”,0, “\r\n”)
#load the records
dbLoadRecords "aware.db","P=DZ1,PORT=serial1"
dbLoadRecords "aware.db","P=DZ2,PORT=serial2"
var streamDebug 1
iocInit
> I gleaned the above from an example but am not sure what much of it means, for example dbLoadRecords "aware.db","P=DZ,BUS=L0 28"
That loads a database definition file (aware.db that you listed previously) into the run-time EPICS database.  It passes a parameter P that is the prefix for the record names, and BUS (changed to PORT in my example) telling it the name of the asyn port driver to communicate with.
> I also did not see in the example how to set the baud rate, etc.
I have added that in my example for the local serial port (/dev/ttys0).
> StreamDevice might be overkill so my question is, if the customer wants to periodically poll the monitor for current reading and do something with it, for example plot, sound an alarm, etc. which would be the best solution StreamDevice, asynDriver or some other solution?
StreamDevice is not overkill, it is exactly what you want.  It talks to an underlying generic asynDriver for the local serial port, or Moxa terminal server, etc.  With this solution the user does not need to write any C code.
Cheers,
From: [email protected] [mailto:[email protected]] On Behalf Of Bryan J. Boardman / Aware Electronics Corp.
Sent: Tuesday, July 22, 2014 2:18 PM
To: [email protected]
Subject: StreamDevice, asynDriver or some other solution?
Hello good people,
Our company manufactures a line of radiation detectors that can be controlled and report data by-way-of RS232 connections using ASCII characters and/or binary.  The monitors include both a standard built-in RS-232 serial port and a built-in USB port using FTDI chip. (FTDI devices now supported in Ubuntu 11.10, kernel 3.0.0-19 http://www.ftdichip.com/Drivers/VCP.htm )
Our monitors default to 9600 baud, 8 data, 1 stop and can be used with RS-232 to Ethernet Serial Device Servers such as: http://www.moxa.com/product/Serial_Device_Servers.htm RS232 to WiFi, GSM modems, etc.
An overseas customer of ours is converting their nuclear facility to EPICS and they would like to use it to, among other things, gather data from and control our monitors.
They state: “As regard EPICS, we are now first stage which install the base configuration of EPICS (3.14.12 VERSION) at Ubuntu 14.04.  We are testing (editing and compiling) and learning the saving the data (histogram), alarming and reporting procedure.”
An example command for our monitor: If one sends it the four characters: BELL,P,CR,LF the monitor responds with an ASCII string floating point number terminated with CRLF, indicating the current reading.
The other commands are similar.
I previously mentioned to the customer that perhaps the StreamDevice is the best approach and that a protocol file (aware.proto) is needed along  these lines:
Terminator = CR LF;
get_aware_reading {
    out "\aP"; in "%f";
    field (OUT,  "@aware.proto info $(BUS)")
dbLoadDatabase " /streamApp.dbd"
#setup the busses
#drvAsynIPPortConfigure "L0", "localhost:40000"
vxi11Configure "L0","gpib-dz-1",0,0.0,"gpib0",0,0
#load the records
var streamDebug 1
iocInit
#enable debug output
var streamDebug 1
I would like to provide the customer with as much information as possible regarding using our monitors with EPICS particularly since they are on the EPICS learning curve, so any and all information and specific examples to accomplish the above would be most appreciated.
Best Regards / Bryan Boardman / Manager / Aware Electronics Corp
Web Site:
http://www.aw-el.com
E-Mail:
[email protected]
Re: StreamDevice, asynDriver or some other solution? Rod Nussbaumer
StreamDevice, asynDriver or some other solution? Bryan J. Boardman / Aware Electronics Corp.
Prev: StreamDevice, asynDriver or some other solution? Bryan J. Boardman / Aware Electronics Corp.
Next: RE: synApps usage on 64 bit systems Mooney, Tim M.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: StreamDevice, asynDriver or some other solution? Rod Nussbaumer
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
