More study. Instead of setting PINI="YES", you could set STAT and SEVR to zero.
Evidently, the reason access-security doesn't get the right value at boot time for PVs used in its calculations,
is that it ignores monitors from PVs if the records hosting them are in alarm. You can get the record out of
alarm by processing it, or by setting (in the database file) the alarm fields to non-alarm values.
Tim
I get that behavior for any value of a PV used in an access-security rule,
whether it was defined in the database or restored by autosave. If I
set PINI to get the record processed at init time, it behaves as I think it
should.
record(bo,"$(P)LocalAccess") {
field(DESC,"AS for Local PCs")
field(DTYP,"Soft Channel")
field(ZNAM,"Disabled")
field(ONAM,"Enabled")
field(ASG, "controlFields")
field(PINI, "YES")
field(UDF, "0")
Tim
I need some advices on rules and autosave.
I configured a Linux IOC with following rules
ASG(FAISCEAU) {
#Operation mode lock
INPA(DEFAULT:OPState)
#BEAM characteristics lock
INPB(FAISCEAU:WritePerm)
# We can always read PVs
RULE(1,READ)
# BEAM Characteristcs could be changed by everyone in maintenance mode and BEAM characteristics unlocked
RULE(1,WRITE) { CALC("A=0 && B=1") }
# BEAM Characteristcs could be changed only by operators in operation mode and BEAM characteristics unlocked
RULE(1,WRITE) {
UAG(operateurs)
CALC("A=1 && B=1")
DEFAULT:OPState could be 0:Maintenance 1:Operation
FAISCEAU:WritePerm could be 0:BEAMLocked 1:BEAMUnlocked
These rules work perfectly when values of DEFAULT:OPState and FAISCEAU:WritePerm are changed manually.
At starting, with autosave mechanisme, there is a mismatch between right access and lock values.
Any ideas?
Dominique.
- security rules and autosave Touchard Dominique
- RE: security rules and autosave Mooney, Tim M.
RE: synApps usage on 64 bit systems Mark Rivers
StreamDevice, asynDriver or some other solution? Bryan J. Boardman / Aware Electronics Corp.
<2014>
synApps usage on 64 bit systems Henrique Dante de Almeida
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
