I get that behavior for any value of a PV used in an access-security rule,
whether it was defined in the database or restored by autosave. If I
set PINI to get the record processed at init time, it behaves as I think it
should.
record(bo,"$(P)LocalAccess") {
field(DESC,"AS for Local PCs")
field(DTYP,"Soft Channel")
field(ZNAM,"Disabled")
field(ONAM,"Enabled")
field(ASG, "controlFields")
field(PINI, "YES")
field(UDF, "0")
Tim
I need some advices on rules and autosave.
I configured a Linux IOC with following rules
ASG(FAISCEAU) {
#Operation mode lock
INPA(DEFAULT:OPState)
#BEAM characteristics lock
INPB(FAISCEAU:WritePerm)
# We can always read PVs
RULE(1,READ)
# BEAM Characteristcs could be changed by everyone in maintenance mode and BEAM characteristics unlocked
RULE(1,WRITE) { CALC("A=0 && B=1") }
# BEAM Characteristcs could be changed only by operators in operation mode and BEAM characteristics unlocked
RULE(1,WRITE) {
UAG(operateurs)
CALC("A=1 && B=1")
DEFAULT:OPState could be 0:Maintenance 1:Operation
FAISCEAU:WritePerm could be 0:BEAMLocked 1:BEAMUnlocked
These rules work perfectly when values of DEFAULT:OPState and FAISCEAU:WritePerm are changed manually.
At starting, with autosave mechanisme, there is a mismatch between right access and lock values.
Any ideas?
Dominique.
- RE: security rules and autosave Mooney, Tim M.
- security rules and autosave Touchard Dominique
synApps usage on 64 bit systems Henrique Dante de Almeida
RE: synApps usage on 64 bit systems Mark Rivers
<2014>
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
