Hello, while using synApps with a test scaler IOC in a 64 bit linux machine I noticed some problems while reading and writing PV values. The problem was tracked down by another developer, some time ago, to be in synApps/support/std-*/src/scalerRecord.c, where the scalerRecord elements pr1, pr2, etc. are accessed using an unsigned long pointer (a type coercion to handle them as if they were a simple array). For example, in process():
static long process(pscal)
scalerRecord *pscal;
unsigned long *ppreset = (unsigned long *)&(pscal->pr1);
Since pr1 and all other pr* are type epicsUInt32, using ppreset to access
the preset values is not supposed to work. Can anyone confirm this ?
The proposed patch was to replace the cast to unsigned long * to epicsUInt32 *,
or similar. Changing only process() and updateCounts() to use a 32 bit type was
enough to make the test scaler to work. I noticed that there are other variables
of type unsigned long, though. Would it make sense to write a patch to change all
the relevant variables to a fixed 32 bit type ?
- RE: synApps usage on 64 bit systems Mark Rivers
- RE: synApps usage on 64 bit systems Mooney, Tim M.
security rules and autosave Touchard Dominique
RE: security rules and autosave Mooney, Tim M.
<2014>
<2014>
