On 16.07.2014 14:00, Dirk Zimoch wrote:
Newer C++ compilers consider more and more things in EPICS errors. And
maybe they are right.
The problem is
T * volatile * buffer;
in epicsRingPointer.h.
I am not sure if "volatile" really makes any sense here.
The other possibility is to cast away the "void" in the destructor.
delete [ ] (T*) buffer;
delete [ ] (T**) buffer;
Or whatever the nicer C++ syntax is (probably using const_cast<T*>()?)
Dirk
epicsRingPointer.cpp
..\..\..\src\libCom\ring\epicsRingPointer.h(93) : *error C2664: 'delete'
: cannot convert parameter 1 from 'void *volatile * ' to 'void *'*
* Conversion loses qualifiers*
..\..\..\src\libCom\ring\epicsRingPointer.cpp(82) : while compiling
class-template member function '__thiscall
epicsRingPointer<void>::~epicsRingPointer<void>(void)'
make[3]: Leaving directory
`C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom'
make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src'
*/The following code is written in epicsRingPointer.h (line 93):/*
inline epicsRingPointer<T>:: ~epicsRingPointer( )
{ delete [ ] buffer; }
If anyone can suggest us the solution to overcome this error it will be
of help to us.
Amit Chauhan,
RRCAT, Indore
- EPICS on VxWorks6.9 Amit Chauhan
- Re: EPICS on VxWorks6.9 Dirk Zimoch
RE: EPICS on VxWorks6.9 Mark Rivers
<2014>
<2014>
