1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS on VxWorks6.9
To: [email protected]
Date: Wed, 16 Jul 2014 14:00:05 +0200
Newer C++ compilers consider more and more things in EPICS errors. And maybe they are right.
The problem is
    T  * volatile * buffer;
in epicsRingPointer.h.
I am not sure if "volatile" really makes any sense here.
The other possibility is to cast away the "void" in the destructor.
delete [ ] (T*) buffer;
Or whatever the nicer C++ syntax is (probably using const_cast<T*>()?)
Dirk
On 16.07.2014 08:14, Amit Chauhan wrote:
We are trying to put EPICS on VxWorks.
Various information related to our setup are:
          EPICS base version : 3.14.12.4
          VxWorks Version : 6.9
Workbench version : 3.3
          Host Architecture : win32 on x86
          Target Architecture: ppc-32
          Target Board :  MVME-5500 with PowerPC 7447 processor
On running the ‘make’ command, the EPICS build stops after a while with
an error.
*_Following is the output of the make command:_*
make -C ./configure install
make[1]: Entering directory `C:/EPICS/base-3-14-12-4/configure'
perl ../src/tools/makeMakefile.pl O.win32-x86 ../..
perl ../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../.. T_A=win32-x86 install
make[2]: Entering directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/configure/O.win32-x86'
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. T_A=vxWorks-ppc32 install
`C:/EPICS/base-3-14-12-4/configure/O.vxWorks-ppc32'
make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/configure'
make -C ./src install
make[1]: Entering directory `C:/EPICS/base-3-14-12-4/src'
make -C ./tools install
make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools'
perl ../../src/tools/makeMakefile.pl O.win32-x86 ../../..
perl ../../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../../..
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools/O.win32-x86'
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. T_A=vxWorks-ppc32
install
`C:/EPICS/base-3-14-12-4/src/tools/O.vxWorks-ppc32'
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/tools'
make -C ./makeBaseApp install
make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp'
perl C:\EPICS\base-3-14-12-4/bin/win32-x86/makeMakefile.pl O.win32-x86
`C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.win32-x86'
install
`C:/EPICS/base-3-14-12-4/src/makeBaseApp/O.vxWorks-ppc32'
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseApp'
make -C ./makeBaseExt install
make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt'
`C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.win32-x86'
install
`C:/EPICS/base-3-14-12-4/src/makeBaseExt/O.vxWorks-ppc32'
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/makeBaseExt'
make -C ./libCom install
make[2]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom'
make[3]: Entering directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
perl ../../../src/libCom/misc/makeEpicsVersion.pl
../../../configure/CONFIG_BASE_VERSION ../O.Common
Building epicsVersion.h from ../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 3.14.12.4
"Installing generated generic include file
C:\EPICS\base-3-14-12-4/include/epicsVersion.h"
rc -l 0x409 -I. -I../O.Common -I. -I../../../src/libCom/osi/os/WIN32
-I../../../src/libCom/osi/os/default -I..
-I../../../src/libCom/bucketLib -I../../../src/libCom/ring
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/env -I../../../src/libCom/error
-I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
-I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/logClient -I../../../src/libCom/macLib
-I../../../src/libCom/misc -I../../../src/libCom/osi
-I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/tsDefs -IC:\EPICS\base-3-14-12-4/include/os/WIN32
-IC:\EPICS\base-3-14-12-4/include -fo Com.res ../Com.rc
cl -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
/D_CRT_NONSTDC_NO_DEPRECATE   /Ox /GL   /W3 /w44355       /MT
-DEPICS_DLL_NO -I. -I..\\O.Common -I.
-I..\\..\\..\\src\\libCom\\osi\\os\\WIN32
-I..\\..\\..\\src\\libCom\\osi\\os\\default -I..
-I..\\..\\..\\src\\libCom\\bucketLib -I..\\..\\..\\src\\libCom\\ring
-I..\\..\\..\\src\\libCom\\calc -I..\\..\\..\\src\\libCom\\cvtFast
-I..\\..\\..\\src\\libCom\\cppStd
-I..\\..\\..\\src\\libCom\\cxxTemplates -I..\\..\\..\\src\\libCom\\dbmf
-I..\\..\\..\\src\\libCom\\ellLib -I..\\..\\..\\src\\libCom\\env
-I..\\..\\..\\src\\libCom\\error -I..\\..\\..\\src\\libCom\\fdmgr
-I..\\..\\..\\src\\libCom\\freeList -I..\\..\\..\\src\\libCom\\gpHash
-I..\\..\\..\\src\\libCom\\iocsh -I..\\..\\..\\src\\libCom\\logClient
-I..\\..\\..\\src\\libCom\\macLib -I..\\..\\..\\src\\libCom\\misc
-I..\\..\\..\\src\\libCom\\osi -I..\\..\\..\\src\\libCom\\taskwd
-I..\\..\\..\\src\\libCom\\timer -I..\\..\\..\\src\\libCom\\tsDefs
-IC:\EPICS\base-3-14-12-4\\include\\os\\WIN32
..\\..\\..\\src\\libCom\\bucketLib\\bucketLib.c
bucketLib.c
cl /nologo /EHsc /GR -c /nologo /D__STDC__=0 /D_CRT_SECURE_NO_DEPRECATE
-DEPICS_DLL_NO /TP   -I. -I..\\O.Common -I.
..\\..\\..\\src\\libCom\\ring\\epicsRingPointer.cpp
..\..\..\src\libCom\ring\epicsRingPointer.h(93) : *error C2664: 'delete'
: cannot convert parameter 1 from 'void *volatile * ' to 'void *'*
*        Conversion loses qualifiers*
..\..\..\src\libCom\ring\epicsRingPointer.cpp(82) : while compiling
class-template member function '__thiscall
epicsRingPointer<void>::~epicsRingPointer<void>(void)'
make[3]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom/O.win32-x86'
make[2]: Leaving directory `C:/EPICS/base-3-14-12-4/src/libCom'
make[1]: Leaving directory `C:/EPICS/base-3-14-12-4/src'
*/The following code is written in epicsRingPointer.h (line 93):/*
inline epicsRingPointer<T>:: ~epicsRingPointer( )
{ delete [ ] buffer; }
If anyone can suggest us the solution to overcome this error it will be
of help to us.
Amit Chauhan,
RRCAT, Indore
Re: EPICS on VxWorks6.9 Dirk Zimoch
RE: EPICS on VxWorks6.9 Mark Rivers
EPICS on VxWorks6.9 Amit Chauhan
Prev: EPICS on VxWorks6.9 Amit Chauhan
Next: Re: EPICS on VxWorks6.9 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
