Changing the mask from "INTEGER:" to "(" fixed my problem.
Now everything works just fine!
Thanks for the help
Florian
On 07/02/2014 02:07 PM, John A. Priller wrote:
The first thing I notice is that the "reply mask" from your INP field
is set to INTEGER:, but that won't work parsing the reply string of
"INTEGER: off(0)" because "off(0)" isn't an integer. Try using '(' as
your mask:
field( INP, "@$(CRATE) %{WCR}outputSwitch.$(CH) ( 100")
Whether that's what's causing your problem with dbpf to the .PROC I
don't know, but it is a problem.
On 07/02/2014 01:47 AM, Florian Feldbauer wrote:
Hey,
yes both records show up, when I run the `dbl` command.
Also there is no error message at initialization.
epics> snmpr 2 PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff
devSnmp report
read task loops : 3034376 (49.8 per sec)
send task loops : 3034301 (49.8 per sec)
active requests : 0
host wienerpl506
SNMP version : SNMP_VERSION_2c
Max OIDS/req : 32
Get Queue items : 0
Set Queue items : 0
Active sessions : 0
Group 'guru'
Host : wienerpl506
Send count : 56804
Reply count : 56804
Error count : 0
Avg reply time : 0.0 msec
Best reply time : 0 msec
Worst reply time : 20 msec
PV count : 34
OID count : 20
PVs:
PV 'PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff'
OID name : WIENER-CRATE-MIB::outputSwitch.u0
Host/Community : wienerpl506/guru
Set type : 's'
Special flags : 0x0000
Settings count : 0
Max data length : 100
Raw value string : 'INTEGER: off(0)'
Reply mask : 'INTEGER:'
Value string : 'off(0)'
OIDs:
verifying devSnmp tasks are running...
sendTask is alive
sendTask_abort : 0
sendTask_exited : 0
globalLastTick : 2014/07/02 08:37:21
readTask is alive
readTask_abort : 0
readTask_exited : 0
readTask_inSelect : 0
readTask_fds : 18
readTask_block : 0
readTask_ignoreBlocks : 0
readTask_timeout : 9 sec 995935 usec
I've just noticed, that the record seems to update correctly but with
a READ_ALARM.
The record bo/longout combination for setting
WIENER-CRATE-MIB::outputSwitch.u0 is working fine...
Concerning the mb/bi/o/direct records: for thinks like the switch
on/off stuff it would be nice...(since you don't need the additional
longin/out record anymore)
originally I also wanted to use mbbiDirect for the outputStatus, but
this has 20 bits, so in this case one needs the longin/calc records
anyway...
Best regards,
Florian
On 07/02/2014 03:20 AM, John A. Priller wrote:
I might be a little slow helping debug it, I'm away from work until
July 10. Do the PV names you're trying to access show up in a 'dbl'
command? If so, what shows up when you have the snmp driver do a
dump of them? For example:
will do a level-2 debug dump of PV/oid info.
The reason we don't support mbbo/i/direct (yet, anyway) is simply
because the old snmp driver we based on version on didn't support it
and we've never yet needed it. It's something we could add if
there's demand for it (and time is available, you know how that goes).
On 07/01/2014 09:00 AM, Florian Feldbauer wrote:
Hey John, hey all,
we have a Wiener PL506 low voltage power supply in our lab
controlled via SNMP.
I tried using the devSnmp module from NSCL
(https://groups.nscl.msu.edu/controls/)
Nearly everything is working just fine, except for two records:
record (longin,
"PANDA:$(subsys):$(dev):LV:$(sector):ReadSwitchOnOff") {
field( DTYP, "Snmp")
field( INP, "@$(CRATE) %{WCR}outputSwitch.$(CH) INTEGER: 100")
record (longin,
"PANDA:$(subsys):$(dev):LV:$(sector):ReadRegulationMode__" ) {
field( DTYP, "Snmp" )
field( INP, "@$(CRATE) %{WCR}outputRegulationMode.$(CH) INTEGER:
100" )
$(CRATE) is the IP-Address of the PL506, %{WCR} = "guru
WIENER-CRATE-MIB::"
and $(CH) is "u0".
When I try to process these records, I get the following error:
epics> dbpf PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff.PROC 1
filename="../dbTest.c" line number=375
No such file or directory - dbPutField error
Any idea what's goning wrong here?
Another question to John: Is there a particular reason why e.g.
mbbi/o(Direct) or bi/o records are not supported by devSnmp?
Best regards,
Florian
| Dr. Florian Feldbauer |
| Helmholtz-Institut Mainz / |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36 |
| D-55128 Mainz |
| Office: SB1 / 00-213 |
| Phone: (+49)6131 / 39-29605 |
- Re: Problems using devSnmp from NSCL John A. Priller
RE: sscan records Mooney, Tim M.
Device support for a simple network ping Phillip Sorensen
<2014>
autosave R5-4 Mooney, Tim M.
<2014>
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
