I might be a little slow helping debug it, I'm away from work until July
10. Do the PV names you're trying to access show up in a 'dbl'
command? If so, what shows up when you have the snmp driver do a dump
of them? For example:
snmpr 2 PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff
will do a level-2 debug dump of PV/oid info.
The reason we don't support mbbo/i/direct (yet, anyway) is simply
because the old snmp driver we based on version on didn't support it and
we've never yet needed it. It's something we could add if there's
demand for it (and time is available, you know how that goes).
On 07/01/2014 09:00 AM, Florian Feldbauer wrote:
Hey John, hey all,
we have a Wiener PL506 low voltage power supply in our lab controlled
via SNMP.
I tried using the devSnmp module from NSCL
(https://groups.nscl.msu.edu/controls/)
Nearly everything is working just fine, except for two records:
record (longin, "PANDA:$(subsys):$(dev):LV:$(sector):ReadSwitchOnOff") {
field( DTYP, "Snmp")
field( INP, "@$(CRATE) %{WCR}outputSwitch.$(CH) INTEGER: 100")
record (longin,
"PANDA:$(subsys):$(dev):LV:$(sector):ReadRegulationMode__" ) {
field( DTYP, "Snmp" )
field( INP, "@$(CRATE) %{WCR}outputRegulationMode.$(CH) INTEGER:
100" )
$(CRATE) is the IP-Address of the PL506, %{WCR} = "guru
WIENER-CRATE-MIB::"
and $(CH) is "u0".
When I try to process these records, I get the following error:
epics> dbpf PANDA:LMD:MUPIX:LV:TEST:ReadSwitchOnOff.PROC 1
filename="../dbTest.c" line number=375
No such file or directory - dbPutField error
Any idea what's goning wrong here?
Another question to John: Is there a particular reason why e.g.
mbbi/o(Direct) or bi/o records are not supported by devSnmp?
Best regards,
Florian
- Re: Problems using devSnmp from NSCL Florian Feldbauer
sscan records Christian Pauly
Re: sscan records Mi Qingru
<2014>
<2014>
