1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: What to do when device initialisation fails
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 30 Jun 2014 15:27:03 +0000
Hi Nick,
Setting pact=TRUE seems to be the accepted solution for unrecoverable errors in device support init_record.  For example, it is used in base 3.14.12.4 in:
src/dev/devSoft/devGeneralTime.c
src/dev/testDev/devHistogramTestAsyn.c.
In synApps it is used in
devMotorAsyn.c
devScalerAsyn.c
devMcaAsyn.c
devBusyAsyn.c
devAsynSoftGlue.c
It is used in all of the standard asyn device support in asyn/devEpics, including devAsynOctet.c.  The only exception seems to be in devAsynOctet.c in iniDrvUser, where it only prints an error message but does not return an error or set pact.
There does seem to be a deficiency in the asyn device support because it does set pact=1 but does not return an error to the function that called init_record. The examples in EPICS base return S_db_badField when they detect an error in init_record.
-----Original Message-----
Sent: Monday, June 30, 2014 3:53 AM
To: Mark Rivers; [email protected]
Hi Mark,
I am not sure if setting PACT=1 is the right thing to do. After thinking about it over the weekend, maybe:
1. I am inclined to have an undefined parameter index value (i.e. probably -1, but defined with a #define) and return it, and check for it in the parameter library.
2. I think device support should set the record into major alarm state with a link alarm condition.
3. I agree that the record should be disabled in some way, but is setting pact=1 the right way?
I am more labouring the point because now nearly all hardware is done with asyn drivers, getting this right is pretty important.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
Sent: 27 June 2014 18:35
To: Rees, Nick (DLSLtd,RAL,TEC); [email protected]
Hi Nick,
I took a quick look, and it seems like all of the other asyn device support the initCommon sets pact=1 and returns -1 if there is an error in processing the drvUser or other calls.  However, the record-specific initialization functions that call initCommon (initAi, etc.) immediately return 0 rather than the error return from initCommon in case of a failure.  Thus the init_record function in aiRecord.c does not get an error return.  This seems wrong to me, but Marty wrote it so it needs to be looked at carefully to see if it is OK.
The devAsynOctet code is different from all of the others.  It does not call drvUserCreate in initCommon, but in another function initDrvUser, which as you said does not set pact=1 on error.  Some of the record-type specific functions call initDrvUser and some do not.  I don't understand this, it seems like they should all call be processing the drvUser field, and so this should be put into initCommon like it is for other device support.
I'm happy to have you look at making this more consistent.
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Friday, June 27, 2014 12:01 PM
To: [email protected]
Subject: What to do when device initialisation fails
All,
What is the correct thing to do when a bad link name is encountered at initialisation?
We recently had a problem when an string parameter was badly named in the OUT link of  stringoutRecord of an areaDetector device. This printed an error message at start up (which no-one saw) but didn't disable the record and subsequent writes to the record (by autosave/restore) trashed the first parameter in the device (which was also a string). I don't think this is the right thing to do.
The rough call chain at the time of the problem is that iocInit initialises the record by calling:
prec->rset->init_record (i.e. init_record in stringoutRecord.c)
  prec->dset->init_record (i.e. initSoWrite in devAsynOctet.c)
    initDrvUser in devAsynOctet.c
       asynPortDriver::drvUserCreate in asynPortDriver.cpp
The bottom routine prints an error message because it can't find the parameter and returns bad status but doesn't change pasynUser->reason.
Then initDrvUser also printed an error, but couldn't do anything more since it is a void function. Hence the record didn't know there was a problem and believed that initialisation had succeeded.
If it did return an error it could propagate it up to the initSoWrite function which has access to the record structure and so could change the value of fields or return an error to record support. If record support gets an error it returns it to iocInit, but otherwise ignores it. iocInit then ignores any bad status.
The options are:
 - set the reason to -1 and check for it in asynPortDriver so any subsequent write fails.
 - change initDrvUser to return a status and disable the record somehow (or set it to Soft Channel) in device support, record support or iocInit.
In similar circumstances devAsynInt32 tries to disable the record by setting pact to 1 and returning a bad status - is this the right thing to do? I looked at various other device drivers and consistency wasn't a feature. Some called recGblRecordError, but this only prints a message, doesn't disable the record.
I know that consistency in device support isn't one of EPICS's features, but if we could decide on a reasonable approach I would be happy to make asyn adhere to it...
Cheers,
Nick Rees
Re: What to do when device initialisation fails Andrew Johnson
What to do when device initialisation fails nick.rees
RE: What to do when device initialisation fails Mark Rivers
RE: What to do when device initialisation fails nick.rees
Prev: Re: What to do when device initialisation fails Benjamin Franksen
Next: Re: What to do when device initialisation fails Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: What to do when device initialisation fails nick.rees
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
