1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Potential failure mode with pmacAsynMotor
To: Emma Shepherd <[email protected]>
Date: Wed, 18 Jun 2014 14:08:19 +0000
Hi Emma,
This would be a problem in the pmacAsynMotorPort driver too. I would suggest using an Asyn parameter to control this, defaulting to disabled. It would be easy to add to the model 3 driver. It's a bad idea to disable hardware limits as part of a homing routine, and I imagine it was originally added to get around PMAC limitations. But it sounds like it's possible to avoid it altogether, using the 'flag low' setting.
Cheers,
Matt
On Jun 18, 2014, at 12:16 AM, Emma Shepherd <[email protected]> wrote:
> Hi everyone,
> I've recently come across an issue with the pmacAsynMotor driver that I thought I should share, as the consequences can be quite severe!
> The driver is designed to support homing onto a limit ('flag high'), which requires limits to be disabled (by setting the appropriate bit of ixx24) in order to work.
> Since this is quite a dangerous thing to do, we have been typically setting up homing to capture on the release of the limit instead ('flag low').  However, I've discovered that if you have got the homing direction set incorrectly (e.g. -ve direction when homing off the negative switch), this results in limits being disabled and the motor driving through the switch.
> You can turn off this behaviour by commenting out the #define REMOVE_LIMITS_ON_HOME, but by default this is included so I'm just letting people know in case they are not already aware of it!
> If other people do want to use the feature of disabling limits, I think it would be worth revisiting the driver to make this safer.  For example if the home type is 'flag low', disabling limits should not be necessary, so we could at least check for this case.
> Cheers,
> Emma
Potential failure mode with pmacAsynMotor Emma Shepherd
Prev: Re: ASYN port driver for file IO? Benjamin Franksen
Next: Generating a 'binary output pulse' by processing an ao record? Nicklas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Potential failure mode with pmacAsynMotor Emma Shepherd
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
