1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM XY Graph
To: "Allison, Stephanie" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 17 Jun 2014 22:01:43 -0700
Ah, Thanks Stephanie.  I did not realize that.
I will try EpicsQt x-y plot widget.
Zen
On 06/17/14 14:56, Allison, Stephanie wrote:
Hi Zen,
Why is the widget showing 11 point when NORD is 10?
Actually, that 11th point is actually 990 points plotted on top of each other so that it looks like 1 point.
In my experience (and perhaps someone knows a way around this), EDM doesn't care about NORD.  It plots everything returned by channel access which is NELM (1000) points.  What I do to make the plot look right is to fill in the unused part of the waveform with the same last value so that the 10th point is 991 values plotted on top of each other.  What a kluge.
Hopefully, someone has a better way around this.  Hopefully, tools like MEDM and BOY plot only NORD of a waveform instead of NELM in their X-Y graph equivalents.
Stephanie Allison
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf
Of Zenon Szalata
Sent: Tuesday, June 17, 2014 12:27 PM
To: [email protected]
Subject: EDM XY Graph
I am developing an IOC to fit data using Chi Square fitting routine.
This is working well.  I don't understand why the EDM x-y graph widget
is showing one extra point, see attachment.
Here are the test data that is being fitted with a quadratic function:
-1.7237128     23.095947     0.2
-1.3703436     15.971818     0.2
-0.96608055    10.204468     0.2
-0.28394297     5.40507      0.2
-0.14970151     4.9337711    0.2
   0.042581975    4.7668524    0.2
   0.82065094     8.7348375    0.2
   1.3416969     15.787588     0.2
   1.3757038     16.520903     0.2
   1.8712276     26.449392     0.2
   where the first column is x, second is y, and third is error on y.
The EDM graph shows the y data points as circles (red) and the fitted
curve (blue).
I have three waveform records of type FLOAT and NELM 1000.  When these
waveforms are filled with data, NORD is 10 in each record.
I don't know how to make it not show the 11th point at (0,0).
Can it be done by changing some parameter in EDM?
I see this behavior in an older version of EDM as well as in version
1-12-96.
Any suggestions will be welcome.
Zen
EDM XY Graph Zenon Szalata
RE: EDM XY Graph Allison, Stephanie
Prev: Potential failure mode with pmacAsynMotor Emma Shepherd
Next: Re: ASYN port driver for file IO? Torsten Bögershausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: EDM XY Graph Allison, Stephanie
Next: Potential failure mode with pmacAsynMotor Emma Shepherd
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
