1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: ASYN port driver for file IO?
To: Ralph Lange <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 17 Jun 2014 14:26:29 +0000
Hi Ralph,
You probably want to support asynOctet->write (to write the name of the file to be read) and asynOctet->read to return the contents of the first line of the file.  Whether you want to implement a poller thread and make the read records be I/O Intr scan depends on the application.  This is all easier of course if you inherit from asynPortDriver.
A limitation of streamDevice is that it does not support the asyn drvUser interface, so you cannot pass your driver a string that controls what "parameter" is being addressed from streamDevice, like you can with the standard asyn device support.
From: [email protected] [[email protected]] on behalf of Pearson, Matthew R. [[email protected]]
Sent: Tuesday, June 17, 2014 8:59 AM
To: Ralph Lange
Cc: EPICS Tech-Talk
Subject: Re: ASYN port driver for file IO?
If no one has done this, there might be some hints from asynNDArrayDriver in areaDetector. That implements the writeOctet function, so that when a file path is written (via the NDAttributesFile parameter) the function triggers a read of that file, which you could then extract information from and populate other parameters. The line number could be another parameter set at runtime.
Or, another way of doing it would be to read the file periodically in a polling thread, perhaps enabled and disabled by another parameter.
Cheers,
Matt
On Jun 17, 2014, at 8:26 AM, Ralph Lange <[email protected]> wrote:
> All,
> I was wondering if anyone has written an ASYN port driver for file read access.
> Something that on every read returns a (run-time) configurable line of a (start-up) configurable file, for example.
> Intended use: Read stuff from the /proc file system using StreamDevice.
> Thanks for any hints,
> ~Ralph
ASYN port driver for file IO? Ralph Lange
Re: ASYN port driver for file IO? Pearson, Matthew R.
Prev: Re: ASYN port driver for file IO? Stephen Beckwith
Next: EDM XY Graph Zenon Szalata
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ASYN port driver for file IO? Pearson, Matthew R.
Next: Re: ASYN port driver for file IO? Stephen Beckwith
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
