1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: ASYN port driver for file IO?
To: Ralph Lange <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 17 Jun 2014 13:59:41 +0000
If no one has done this, there might be some hints from asynNDArrayDriver in areaDetector. That implements the writeOctet function, so that when a file path is written (via the NDAttributesFile parameter) the function triggers a read of that file, which you could then extract information from and populate other parameters. The line number could be another parameter set at runtime.
Or, another way of doing it would be to read the file periodically in a polling thread, perhaps enabled and disabled by another parameter.
Cheers,
Matt
On Jun 17, 2014, at 8:26 AM, Ralph Lange <[email protected]> wrote:
> All,
> I was wondering if anyone has written an ASYN port driver for file read access.
> Something that on every read returns a (run-time) configurable line of a (start-up) configurable file, for example.
> Intended use: Read stuff from the /proc file system using StreamDevice.
> Thanks for any hints,
> ~Ralph
RE: ASYN port driver for file IO? Mark Rivers
ASYN port driver for file IO? Ralph Lange
Prev: Re: Parameter library in asynportdriver /areadetector Pearson, Matthew R.
Next: Re: ASYN port driver for file IO? Stephen Beckwith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: ASYN port driver for file IO? Ralph Lange
Next: RE: ASYN port driver for file IO? Mark Rivers
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
