1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Parameter library in asynportdriver /areadetector
From: "Gomella, Andrew (NIH/NHLBI) [F]" <[email protected]>
Date: Mon, 16 Jun 2014 23:42:06 +0000
I see. I checked over my database and I think there were some problems with it but the strings do match.
The problem is when i put the names of one of my parameters in the writeint32 function instead of the index coming out, I am actually getting the value of that Parameter. I checked this by doing printf of parameter names in my writeInt32 function like this:
printf("Varian Mode %i SaveRaw %i SaveOffset %i SaveCorrected", VarianMode, SaveRaw, SaveOffset, SaveCorrected);
And instead of their indices, I get the values. This is my first C++ program ever, I am probably missing something trivial.
That's a good point- I will change my parameter strings  accordingly.
Thanks!
Andrew
Sent: Monday, June 16, 2014 5:41 PM
To: Gomella, Andrew (NIH/NHLBI) [F]
Cc: [email protected]
Subject: Re: Parameter library in asynportdriver /areadetector
Maybe the problem is your database record for the VarianMode record. Does it's drvInfo field match the definition for that parameter string in your driver?
In general I would recommendations that you prefix all of your parameter strings with VARIAN_ to avoid potential future conflicts with base class parameters.
Sent from my iPhone
> On Jun 16, 2014, at 4:26 PM, "Gomella, Andrew (NIH/NHLBI) [F]" <[email protected]> wrote:
> As always thanks for the quick response. My output from report looks as expected:
> Enabling software handshaking...camera connected
> Port: PS1
>  Timestamp: <undefined>
>  Input EOS[0]:
>  Output EOS[0]:
> Parameter list 0
> Number of parameters is: 99
> Parameter 0 type=string, name=PORT_NAME_SELF, value=PS1, status=0
> Parameter 1 type=asynInt32, name=ARRAY_SIZE_X, value=1, status=0
> Parameter 2 type=asynInt32, name=ARRAY_SIZE_Y, value=2816, status=0
> Parameter 3 type=asynInt32, name=ARRAY_SIZE_Z, value=0, status=0
> Parameter 4 type=asynInt32, name=ARRAY_SIZE, value=20185088, status=0
> Parameter 5 type=asynInt32, name=ARRAY_NDIMENSIONS, value=0, status=0
> Parameter 6 type=asynInt32, name=ARRAY_DIMENSIONS, value is undefined
> Parameter 7 type=asynInt32, name=DATA_TYPE, value=3, status=0
> Parameter 8 type=asynInt32, name=COLOR_MODE, value=0, status=0
> Parameter 9 type=asynInt32, name=UNIQUE_ID, value=0, status=0
> Parameter 10 type=asynFloat64, name=TIME_STAMP, value=0.000000, status=0
> Parameter 11 type=asynInt32, name=EPICS_TS_SEC, value=0, status=0
> Parameter 12 type=asynInt32, name=EPICS_TS_NSEC, value=0, status=0
> Parameter 13 type=asynInt32, name=BAYER_PATTERN, value=0, status=0
> Parameter 14 type=asynInt32, name=ARRAY_COUNTER, value=0, status=0
> Parameter 15 type=string, name=FILE_PATH, value is undefined
> Parameter 16 type=asynInt32, name=FILE_PATH_EXISTS, value is undefined
> Parameter 17 type=string, name=FILE_NAME, value is undefined
> Parameter 18 type=asynInt32, name=FILE_NUMBER, value is undefined
> Parameter 19 type=string, name=FILE_TEMPLATE, value=%s%s_%3.3d.dat, status=0
> Parameter 20 type=asynInt32, name=AUTO_INCREMENT, value is undefined
> Parameter 21 type=string, name=FULL_FILE_NAME, value is undefined
> Parameter 22 type=asynInt32, name=FILE_FORMAT, value is undefined
> Parameter 23 type=asynInt32, name=AUTO_SAVE, value is undefined
> Parameter 24 type=asynInt32, name=WRITE_FILE, value=0, status=0
> Parameter 25 type=asynInt32, name=READ_FILE, value=0, status=0
> Parameter 26 type=asynInt32, name=WRITE_MODE, value is undefined
> Parameter 27 type=asynInt32, name=WRITE_STATUS, value=0, status=0
> Parameter 28 type=string, name=WRITE_MESSAGE, value=, status=0
> Parameter 29 type=asynInt32, name=NUM_CAPTURE, value is undefined
> Parameter 30 type=asynInt32, name=NUM_CAPTURED, value=0, status=0
> Parameter 31 type=asynInt32, name=CAPTURE, value=0, status=0
> Parameter 32 type=asynInt32, name=DELETE_DRIVER_FILE, value is undefined
> Parameter 33 type=string, name=ND_ATTRIBUTES_FILE, value is undefined
> Parameter 34 is undefined, name=ARRAY_DATA
> Parameter 35 type=asynInt32, name=ARRAY_CALLBACKS, value is undefined
> Parameter 36 type=asynInt32, name=POOL_MAX_BUFFERS, value=50, status=0
> Parameter 37 type=asynInt32, name=POOL_ALLOC_BUFFERS, value=0, status=0
> Parameter 38 type=asynInt32, name=POOL_FREE_BUFFERS, value=0, status=0
> Parameter 39 type=asynFloat64, name=POOL_MAX_MEMORY, value is undefined
> Parameter 40 type=asynFloat64, name=POOL_USED_MEMORY, value is undefined
> Parameter 41 type=string, name=MANUFACTURER, value=Varian, status=0
> Parameter 42 type=string, name=MODEL, value=PaxScan 3024M X-ray Imager, status=0
> Parameter 43 type=asynFloat64, name=GAIN, value is undefined
> Parameter 44 type=asynInt32, name=BIN_X, value is undefined
> Parameter 45 type=asynInt32, name=BIN_Y, value is undefined
> Parameter 46 type=asynInt32, name=MIN_X, value is undefined
> Parameter 47 type=asynInt32, name=MIN_Y, value is undefined
> Parameter 48 type=asynInt32, name=SIZE_X, value=3584, status=0
> Parameter 49 type=asynInt32, name=SIZE_Y, value=2816, status=0
> Parameter 50 type=asynInt32, name=MAX_SIZE_X, value=3584, status=0
> Parameter 51 type=asynInt32, name=MAX_SIZE_Y, value=2816, status=0
> Parameter 52 type=asynInt32, name=REVERSE_X, value is undefined
> Parameter 53 type=asynInt32, name=REVERSE_Y, value is undefined
> Parameter 54 type=asynInt32, name=FRAME_TYPE, value is undefined
> Parameter 55 type=asynInt32, name=IMAGE_MODE, value is undefined
> Parameter 56 type=asynInt32, name=NEXPOSURES, value is undefined
> Parameter 57 type=asynInt32, name=NEXPOSURES_COUNTER, value=0, status=0
> Parameter 58 type=asynInt32, name=NIMAGES, value is undefined
> Parameter 59 type=asynInt32, name=NIMAGES_COUNTER, value=0, status=0
> Parameter 60 type=asynFloat64, name=ACQ_TIME, value is undefined
> Parameter 61 type=asynFloat64, name=ACQ_PERIOD, value is undefined
> Parameter 62 type=asynFloat64, name=TIME_REMAINING, value=0.000000, status=0
> Parameter 63 type=asynInt32, name=STATUS, value=0, status=0
> Parameter 64 type=asynInt32, name=TRIGGER_MODE, value is undefined
> Parameter 65 type=asynInt32, name=ACQUIRE, value=0, status=0
> Parameter 66 type=asynInt32, name=SHUTTER_CONTROL, value is undefined
> Parameter 67 type=asynInt32, name=SHUTTER_CONTROL_EPICS, value is undefined
> Parameter 68 type=asynInt32, name=SHUTTER_STATUS, value=0, status=0
> Parameter 69 type=asynInt32, name=SHUTTER_MODE, value is undefined
> Parameter 70 type=asynFloat64, name=SHUTTER_OPEN_DELAY, value is undefined
> Parameter 71 type=asynFloat64, name=SHUTTER_CLOSE_DELAY, value is undefined
> Parameter 72 type=asynFloat64, name=TEMPERATURE, value is undefined
> Parameter 73 type=asynFloat64, name=TEMPERATURE_ACTUAL, value is undefined
> Parameter 74 type=asynInt32, name=READ_STATUS, value is undefined
> Parameter 75 type=string, name=STATUS_MESSAGE, value=, status=0
> Parameter 76 type=string, name=STRING_TO_SERVER, value=, status=0
> Parameter 77 type=string, name=STRING_FROM_SERVER, value=, status=0
> Parameter 78 type=asynInt32, name=VARIAN_MODE, value is undefined
> Parameter 79 type=asynInt32, name=SAVE_RAW, value is undefined
> Parameter 80 type=asynInt32, name=SAVE_OFFSET, value is undefined
> Parameter 81 type=asynInt32, name=SAVE_CORRECTED, value is undefined
> Parameter 82 type=asynInt32, name=BOARDSNBR, value is undefined
> Parameter 83 type=asynInt32, name=COMPLETE, value is undefined
> Parameter 84 type=asynInt32, name=READY_FOR_PULSE, value is undefined
> Parameter 85 type=asynInt32, name=NUM_FRAMES, value is undefined
> Parameter 86 type=asynInt32, name=NUM_PULSES, value is undefined
> Parameter 87 type=asynFloat64, name=TEMP1, value is undefined
> Parameter 88 type=asynFloat64, name=TEMP2, value is undefined
> Parameter 89 type=asynFloat64, name=TEMP3, value is undefined
> Parameter 90 type=asynFloat64, name=TEMP4, value is undefined
> Parameter 91 type=asynFloat64, name=TEMP5, value is undefined
> Parameter 92 type=asynFloat64, name=TEMP6, value is undefined
> Parameter 93 type=asynInt32, name=GAIN_CAL, value is undefined
> Parameter 94 type=asynInt32, name=GAIN_CAL_NUM_OFFSETS, value is undefined
> Parameter 95 type=asynInt32, name=GAIN_CAL_NUM_FLATS, value is undefined
> Parameter 96 type=asynFloat64, name=VARIAN_FRAME_RATE, value is undefined
> Parameter 97 is undefined, name=empty
> Parameter 98 is undefined, name=empty
> But when writeInt32 is called for say VarianMode, it thinks the parameter number for VarianMode is 1, when it should be 78? I'm probably missing something trivial but I really can't find it.
> Thank you,
> Andrew
> From: Mark Rivers [[email protected]]
> Sent: Monday, June 16, 2014 3:35 PM
> If your driver has a varian::report method like other drivers then you can do
> asynReport 10 portName
> where portName is the asyn port name of your driver.
> That will dump the entire parameter library with index numbers, drvInfo strings and parameter values.
> You should see the parameters from asynNDArrayDriver first, then the ones from ADDriver, and finally the ones from your Varian driver.
> Mark
> Sent from my iPhone
>> On Jun 16, 2014, at 1:24 PM, "Gomella, Andrew (NIH/NHLBI) [F]" <[email protected]> wrote:
>> Hi,
>> Yet another question regarding an areadetector driver I am writing (which is now mostly finished).
>> For some reason my parameter library is not getting set to the correct indices. In my writeInt32 function I put some printf statements and found out that my first parameter VarianMode is set to 3, but should be set to 78. (or vice versa?)
>> synStatus varian::writeInt32(asynUser *pasynUser, epicsInt32 value)
>>   int function = pasynUser->reason;
>>   //int status = asynSuccess;
>>   printf("VarianMode: %i", VarianMode);
>>   printf("writeint32 %i %i", function, value);
>>  if (function == 78){
>>       printf("function varian mode called");
>>       vip_select_mode(value); //varian function
>> (Explicitly just saying function ==78 was my quick fix to get things working as expected).
>> When I caput VarianMode 1
>> the first printf gives: VarianMode: 3
>> The second printf gives: writeint32 78 1
>> I've compared my code to many areadetector examples and can't figure out what I am doing wrong? Everything I'm doing seems exactly the same -
>> the declarations, the NUM PARAMS define (which is later used in the constructor)
>> #define NUM_VARIAN_PARAMS ((int)(&LAST_VARIAN_PARAM - &FIRST_VARIAN_PARAM + 1))
>> Any ideas?
>> Thanks,
>> Andrew
>> Imaging Physics Lab, NIH
Re: Parameter library in asynportdriver /areadetector Pearson, Matthew R.
Parameter library in asynportdriver /areadetector Gomella, Andrew (NIH/NHLBI) [F]
Re: Parameter library in asynportdriver /areadetector Mark Rivers
RE: Parameter library in asynportdriver /areadetector Gomella, Andrew (NIH/NHLBI) [F]
Prev: Re: Parameter library in asynportdriver /areadetector Mark Rivers
Next: ASYN port driver for file IO? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Parameter library in asynportdriver /areadetector Pearson, Matthew R.
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
