Hi, From base folder $ pwd /opt/epics/base-3.14.12.4 and in sncseq/configure/RELEASE #EPICS_BASE=/home/phoebus/ANJ/epics/base/3-14-dev EPICS_BASE=/opt/epics/base-3.14.12.4 what is wrong with this setting? With Best Regards Vikram On Friday, June 13, 2014 7:41 PM, Mark Rivers <[email protected]> wrote: It looks to me like you have not correctly defined EPICS_BASE in sncseq/configure/RELEASE.
Sent: Friday, June 13, 2014 12:39 PM To: Mark Rivers; epics talk Subject: Re: sequencer installation I installed base3.14.12.4 but for installation of sequencer, i have
below error make[1]: Leaving directory `/opt/epics/modules/sncseq/configure' make -C ./src install make[1]: Entering directory `/opt/epics/modules/sncseq/src' make -C ./pv install make[2]: Entering directory `/opt/epics/modules/sncseq/src/pv' make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64' make[3]: Nothing to be done for `install'. make[3]: Leaving directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64' make[2]: Leaving directory `/opt/epics/modules/sncseq/src/pv' make -C ./seq install make[2]: Entering directory `/opt/epics/modules/sncseq/src/seq' make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/opt/epics/modules/sncseq/src/seq/O.linux-x86_64' make[3]: *** No rule to make target `../../../lib/linux-x86_64/libiocsh.a', needed by `libseq.a'. Stop. make[3]: Leaving directory `/opt/epics/modules/sncseq/src/seq/O.linux-x86_64' make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory `/opt/epics/modules/sncseq/src/seq' make[1]: *** [seq.install] Error 2 make[1]: Leaving directory `/opt/epics/modules/sncseq/src' make: *** [src.install] Error 2 Please suggest me how to come out from this problem. With best Regards Vikram On Wednesday, June 4, 2014 10:40 PM, Mark Rivers <[email protected]> wrote:
I would suggest using 3.14.12.4 and see if you still have a problem.
________________________________ From: Vikram Bhagat [[email protected]] Sent: Wednesday, June 04, 2014 3:14 PM To: Mark Rivers; epics talk Subject: Re: sequencer installation Dear Mark There nothing special to use EPICS3.15, i am installing in my system so just took latest. Vikram On Wednesday, June 4, 2014 10:09 PM, Mark Rivers <[email protected]> wrote: You are using EPICS 3.15. Do you have a reason for using that? It is still not ready for production systems. Should you be using 3.14.12.4 instead? Mark ________________________________ From: [email protected]<mailto:[email protected]> [[email protected]<mailto:[email protected]>] on behalf of Vikram Bhagat [[email protected]<mailto:[email protected]>] Sent: Wednesday, June 04, 2014 3:02 PM To: epics talk Subject: sequencer installation Hello, I am trying to install sequencer but could not build Below is the log an anyone guide me what is wrong with installation. [root@sarva-PC<mailto:root@sarva-PC> sncseq]# make make -C ./configure install make[1]: Entering directory `/opt/epics/modules/sncseq/configure' make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64 install make[2]: Entering directory `/opt/epics/modules/sncseq/configure/O.linux-x86_64' perl -CSD /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease make[2]: Leaving directory `/opt/epics/modules/sncseq/configure/O.linux-x86_64' make[1]: Leaving directory `/opt/epics/modules/sncseq/configure' make -C ./src install make[1]: Entering directory `/opt/epics/modules/sncseq/src' make -C ./pv install make[2]: Entering directory `/opt/epics/modules/sncseq/src/pv' make -C O.linux-x86_64 -f ../Makefile TOP=../../.. T_A=linux-x86_64 install make[3]: Entering directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64' make[3]: *** No rule to make target `/opt/epics/base-3.15.0.1/include/shareLib.h', needed by `pvNew.o'. Stop. make[3]: Leaving directory `/opt/epics/modules/sncseq/src/pv/O.linux-x86_64' make[2]: *** [install.linux-x86_64] Error 2 make[2]: Leaving directory `/opt/epics/modules/sncseq/src/pv' make[1]: *** [pv.install] Error 2 make[1]: Leaving directory `/opt/epics/modules/sncseq/src' make: *** [src.install] Error 2 [root@sarva-PC<mailto:root@sarva-PC> sncseq]# I set EPICS_BASE=/opt/epics/base in configure/RELEASE Thanks Vikram
ANJ, 17 Dec 2015 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
