1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Compiling helloWorld of EPICS V4 on 64bit linux had a link error [SEC=UNOFFICIAL]
To: <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>, <[email protected]>
Date: Fri, 13 Jun 2014 13:41:04 +0000
Hi Qingru,
Thanks for your emails.
I look after the two examples in exampleCPP.
Both examples, HelloWorld and ChannelArchiverService, currently link against expat. In fact HelloWorld doesn't need to.
So the quickest solution is to remove the line
USR_SYS_LIBS += expat
from HelloWorld/helloWorldApp/Makefile.
I'll make that change to the mercurial repo and it'll be in the next release.
However it sounds like you've got it to build by installing expat-devel. That'll still be useful if you try to build the ChannelArchiverService.
Dave
Sent: 13 June 2014 07:00
To: LYNCH, Damien; Jani Hakala; Hinko Kocevar; [email protected]
Subject:
答复: Compiling helloWorld of EPICS V4 on 64bit linux had a link error [SEC=UNOFFICIAL]
Hi Lynch, Jani, Hinko,
You are right! The expat-devel package hasn't installed. After I installed the expat-devel package with yum, libexpat.so was also installed into /usr/lib64.
Thank you very much!
Qingru Mi
发件人: LYNCH, Damien [[email protected]]
发送时间: 2014612 14:00
: 米清茹; [email protected]
主题: RE: Compiling helloWorld of EPICS V4 on 64bit linux had a link error [SEC=UNOFFICIAL]
Hi Qingru,
Glad to hear it’s working. I suspect the real problem is the expat-devel package is not installed.
Damien
Sent: Thursday, 12 June 2014 3:32 PM
To: LYNCH, Damien; [email protected]
Subject:
Hi Lynch,
    There wasn't libexpat.so. After I created the link, the HelloWorld was built without any error.
Qingru Mi
发送时间: 2014612 11:59
Although you don’t mention libexpat.so. Does that exist?  If not you could create it as a link to libexpat.so.1.
Sent: Thursday, 12 June 2014 1:52 PM
To: LYNCH, Damien; ???; [email protected]
Sorry, ignore that I missed I can find libexpat.so.1 and libexpat.so.1.5.2 in /lib64 in your message.
From: [email protected] [mailto:[email protected]] On Behalf Of LYNCH, Damien
Sent: Thursday, 12 June 2014 1:50 PM
To: ???; [email protected]
I assume expat is the Expat XML parser library. Do you have that installed?
Damien
From: [email protected] [mailto:[email protected]] On Behalf Of ???
Sent: Thursday, 12 June 2014 1:29 PM
To: [email protected]
Subject: Compiling helloWorld of EPICS V4 on 64bit linux had a link error
    I compiled the EPICS-CPP-4.3.0 on 64bit centos6.5. As the HelloWorld in exampleCPP was compiled, an error occured. The error information shows below:
/usr/bin/g++ -o HelloService  -L/BLC/epics/v4/EPICS-CPP-4.3.0/pvAccessCPP/lib/linux-x86_64 -L/BLC/epics/v4/EPICS-CPP-4.3.0/pvDataCPP/lib/linux-x86_64 -Wl,-rpath,/BLC/epics/v4/EPICS-CPP-4.3.0/pvAccessCPP/lib/linux-x86_64 -Wl,-rpath,/BLC/epics/v4/EPICS-CPP-4.3.0/pvDataCPP/lib/linux-x86_64       -m64               HelloServiceMain.o HelloService.o    -lpvAccess -lpvData  -lexpat
/usr/bin/ld: cannot find -lexpat
collect2: ld returned 1 exit status
make[2]: *** [HelloService] Error 1
make[2]: Leaving directory `/BLC/epics/v4/EPICS-CPP-4.3.0/exampleCPP/HelloWorld/helloWorldApp/O.linux-x86_64'
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory `/BLC/epics/v4/EPICS-CPP-4.3.0/exampleCPP/HelloWorld/helloWorldApp'
make: *** [helloWorldApp.install] Error 2
I can find libexpat.so.1 and libexpat.so.1.5.2 in /lib64.
How to resolve the problem?
Qingru Mi
SSRF
RE: Compiling helloWorld of EPICS V4 on 64bit linux had a link error [SEC=UNOFFICIAL] LYNCH, Damien
答复: Compiling helloWorld of EPICS V4 on 64bit linux had a link error [SEC=UNOFFICIAL] 米清茹
Prev: 答复: Compiling helloWorld of EPICS V4 on 64bit linux had a link error [SEC=UNOFFICIAL] 米清茹
Next: RE: Visual Studio 2010 problem and solution Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: EtherIP with CIP Adapter Devices John Dobbins
ANJ, 17 Dec 2015 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
