Hello all,
A feature I use a lot with my db file is overwriting a record, ie:
record(ao, "myAO") {
field(VAL, "20")
field(DRVH, "40")
and later in the same or another db file
field(VAL, "21")
field(FLNK, "AnotherAO")
The above is equivalent to 1 single entry with
record(ao, "mAO") {
field(VAL, "21")
field(DRVH, "40")
Now the issue is that to overwrite the field of a record, you need to know its type (i.e. ao) as you need to repeat the record line.
Is it possible to have a database entry (maybe like the alias entry) where you could just say:
changefield("myAO", VAL, 21)
which doesn't create the record if it doesn't exist, but which perform the equivalent to
field(VAL, "21")
if it does.
Maybe a similar command already exist.
If so let me know,
Emmanuel
